Heat Question
Old Jan 16, 2011 | 06:08 PM
Jon Hess's Avatar
Jon Hess
Heat Question
I'm putting the heat back together in my f150 and I'm wondering if I really need the vacuum actuated valve that is in the heater hose between the motor and heater core. I would assume that it is a shut off valve preventing coolant from going through the heater core when the heat is not on but do I really need it? Thanks
Old Jan 16, 2011 | 06:11 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
It's needed during A/C operation, otherwise it's not needed.
Josh
Old Jan 16, 2011 | 06:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You have factory A/C, otherwise your truck would not have the valve.
D4AZ18495A (replaced D1AZ18495B, C8AZ18495A & C7SZ18495A) .. Heater Water Valve (Motorcraft YG136) / Available from Ford.
This valve is a POS, and has been since day one. Fits myriad 1967/91 Passenger Cars/F100/350's / 1975/91 Econolines & 1978/91 Bronco's. Is notorious for getting stuck open/closed or partially open/closed.
Old Jan 16, 2011 | 06:54 PM
Jon Hess's Avatar
Jon Hess
Ok so since I took out my A/C components I don't need it? What should I do with the vacuum line that ran to it?
Old Jan 16, 2011 | 07:01 PM
Bullitt390's Avatar
Bullitt390
If you removed the a/c components you will not need the valve and you can just plug the vacuum line.
Josh
Old Jan 16, 2011 | 07:14 PM
Jon Hess's Avatar
Jon Hess
Ok sweet thanks for the quick replies.
jstephens2
22
Sep 13, 2011 08:21 PM
fzeed
21
Dec 13, 2008 11:22 PM
77'F-150Mudder
17
Dec 7, 2003 02:18 AM
blue93f150
Oct 2, 2003 09:21 PM
borland
Mar 22, 2001 02:31 PM
