Sponsored by: Kumho
Need Some Rim Width Help Please
Old Jan 16, 2011 | 12:57 PM
JayHenry's Avatar
JayHenry
From a post I made in another section of FTE I have been told the rim width of my factory steel wheels on my 85 4WD F250 is 6", in calling around I have been told 7". Can someone let me know for sure the rim width. Thanks guys.
Old Jan 16, 2011 | 02:19 PM
85e150's Avatar
85e150
My '85 E150 had the size stamped right into the wheel rim on the outside, possibly near the valve stem hole. Get a rag and some 409 and start looking....
I would guess 6", but that's a guess.
Old Jan 16, 2011 | 02:56 PM
JayHenry's Avatar
JayHenry
I used windex and a paper towel. None the less, I found very clear stampings which state 97 then 11 then R.
I have no idea what that stuff is, except the R probably stands for radial.
Old Jan 16, 2011 | 06:19 PM
85e150's Avatar
85e150
My stamping was "15x6JJ" iirc, but if that's all you found, well, that's all there is. You can do an outside measurement, if you find about 7-7.5 inches, that's a 6" rim. Hard to do, but you might be able to put the tape through the wheel.
Old Jan 17, 2011 | 09:32 PM
JayHenry's Avatar
JayHenry
That is what I did and found a width of 7.5" so I guess I have 16x6 8 lug steel wheels. What I want to mount on them is a set of 285/75r16 tires. Is this possible and safe, or do I need to look at other tires, possibly at other wheels?
Old Jan 17, 2011 | 10:37 PM
Kyle 4X4 4life's Avatar
Kyle 4X4 4life
You'd be plenty safe to do that, the 285's are 11.5 inches wide, i have had 12.5 inch wide tires on stock rims so i'd say you'd be plenty safe.
Old Jan 18, 2011 | 07:05 AM
Derrick@TireRack.com's Avatar
Former Vendor
A 285/75R16 will fit a rim width range of 7.5"-9" wide.
Old Jan 18, 2011 | 12:37 PM
Kyle 4X4 4life
Ya thats what they say, i've had 12.5's on my 7" rims for months and never had any problems at all.
Old Jan 18, 2011 | 01:54 PM
Ford_Six's Avatar
Ford_Six
I have 285s on 7" rims right now, I had 315s on them a few years back with no issues. These should be the same rims you have, off an 84 F250.
Old Jan 18, 2011 | 01:58 PM
Former Vendor
Mounting them on a skinnier wheel then is recommended will cause the centers to ride higher and can result in wearing out the middle of the tires faster and not allow them to wear even. Just an fyi.
Old Jan 18, 2011 | 06:26 PM
JayHenry's Avatar
JayHenry
Thanks gents. I will go ahead and order the tires and have them mounted. It's a project truck that I will use for a spare vehicle, for fun, and a general hunting rig once or three times a year. These tires will come first to get it on the road, then a few cosmetic issues, then a 2.5" lift with new shocks. I don't imagine it will see 1,500 hundred miles a year. I will keep my eyes on Craigs list and some salvage yards for a slightly wider steel factory set of wheels, and when I find them I'll have the tires remounted. No hurry. The 460 does eat the gas don't it but it will sure go wherever you point it whether it has a load or not.
