Truck just started Bouncing
Old Jan 16, 2011 | 01:30 PM
firman's Avatar
firman
i know a guy who told me that happened to him, he needed front end rebuilt for something that happens to some trucks, i'll ask him exactly what it was and try to let you know.
Old Jan 16, 2011 | 01:32 PM
benthere's Avatar
benthere
Might be a broken wheel?
Old Jan 16, 2011 | 01:34 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
The "POP" is what scares me.
Old Jan 16, 2011 | 04:09 PM
FredTheMonster's Avatar
FredTheMonster
Not just the "pop" but also the gap in the springs. Is there still a gap in just one side of your springs?
Old Jan 16, 2011 | 05:38 PM
gw1969's Avatar
gw1969
steady bearing on rear driveshaft
i have a 72 gmc 3/4 ton 4x4,same thing heard a pop and lots of up and down action,steady bearing popped out causing drive shaft to flop around
Old Jan 21, 2011 | 08:17 PM
Jbrown8988's Avatar
Jbrown8988
OK guys, sorry i have been busy plowing my *** off. (in 2wd) because it is still doing it. I think GW1969 might be on track with my problem. I can wiggle the front driveshaft up and down about a half inch where it mounts to the axle. Something is wrong in the axle, it is also leaking fluid out of where the driveshaft mounts. I dont know anything about axles.
I will get some pics of the leaf springs as soon as i can. Right now i have to go to bed, getting another 12" of snow tonight. I will need 2 new tires by the time i am done plowing in 2wd!
edit: also my front drive shaft u joint is shot now
Old Jan 21, 2011 | 09:30 PM
mikeyc0120's Avatar
mikeyc0120
indeed sounds like a problem in the front diff or axle.
Old Jan 21, 2011 | 09:31 PM
rbaker6336's Avatar
rbaker6336
Your descriptions are so vague it's hard to tell what may be wrong with front differential or drive shaft,but if your hubs were unlocked as per your original post the drive shaft/diff would be a non issue for the bouncing as it should not be turning.
If the 1/2" movement in the drive shaft is in front of the yoke you at the least have a pinion bearing gone south and should have some noise in the front while in 4WD
Old Jan 22, 2011 | 11:23 AM
Jbrown8988's Avatar
Jbrown8988
I'm not a mechanic so i really don't know how to be much clearer.
The truck didnt come out of 4x4 when i unlocked the hubs. I am thinking when i backed out of my driveway the next morning is when it came out. It sticks when there is a bad ujoint and i have to go in reverse and then forward to get it to come out sometimes.
Thom12
6.7L Power Stroke Diesel
847
Sep 20, 2025 01:12 PM
02TB250
Jul 31, 2017 05:54 PM
sduce
1997 - 2003 F150
Feb 6, 2015 12:10 PM
Crewcabber
77
Oct 26, 2014 01:56 PM
mudslinger02
1997 - 2003 F150
32
Sep 12, 2013 07:43 PM
