Sponsored by: Real Truck
Rear end bouncing
Old Oct 29, 2015 | 09:21 AM
02TB250's Avatar
02TB250
Rear end bouncing
I've been chasing this for longer then i can remember. At 40-45mph the rear end feels like its bouncing. no movement from the steering wheel, just a pulsating bounce
Little information about the truck: Has had Napa Gold shocks, Bilstein 5100s and currently Monroe reflex shocks. Installed readylift 4inch rear block kit about 2 years ago. Had 16x9 rims, currently has factory 16x6.5. Tires are 285/75s. New pads rotors and calipers. It's just driving me nuts to have it bounce all the time.
Old Oct 29, 2015 | 09:28 AM
Chuck's First Ford's Avatar
Chuck's First Ford
tire out of round
wheel out of round
carrier bearing bad
driveshaft out of balance.
slightly bent axle
or a simple wheel out of balance.. rotate front to backs.
Old Oct 29, 2015 | 09:39 AM
lebanontn's Avatar
lebanontn
I would look at bearing first
Old Oct 29, 2015 | 10:28 AM
02TB250's Avatar
02TB250
Originally Posted by Chuck's First Ford
tire out of round
wheel out of round
carrier bearing bad
slightly bent axle
this has done this with 2 separate rims both factory and ATX artillery. 3 separate sets of tires, 265 firestone transforce, 285 BFG ATs 285 BFG rugged terrains. Have had the tires rebalanced 4 or 5 times.
I don't think i have a carrier bearing, I have a 1 piece driveshaft? unless i'm thinking of the wrong thing.
are there tests for the driveshaft or bent axles?
Where would the bearing be?
I have suspected the driveshaft, I'm usually at 1300rpms at 40-45mph. Would it be the balance, or the U-Joints, as far as i know they are original from factory.
Old Oct 29, 2015 | 10:37 AM
Chuck's First Ford
for wheel/tire/axle.. lift rear end (both sides) start engine and put into gear.. SLOW..
from rear of truck watch carefully at tire for small up and down .. each side.
or place a piece of plywood between driveway and tire.. make sure you have 1/8 inch space.. if tire makes contact or 1/8 inch increases .. there is the problem.
you have a Short Bed.. you may NOT have a carrier bearing... I am not sure.
Old Oct 29, 2015 | 01:19 PM
02TB250's Avatar
02TB250
I'll give it a shot, Thanks for the help.
Old Oct 29, 2015 | 02:37 PM
firebirdparts's Avatar
firebirdparts
It's just a tire. As to the diagnosis, keep in mind the rear end will not shake if you have it on jacks (jacks aren't very springy.) That is not going to work.
It might work to have somebody drive behind you and watch (maybe).
Old Oct 29, 2015 | 05:27 PM
Chuck's First Ford
I GUESS you missed the part of the plywood and tire spacing... this is common in the repair shops. when you do not have a 50K frame jig...
out of round tire, wheel, bent axle.. the rear end is NOT to move .. as its on Jacks. the rear end is bouncing because of SOMETHING making it do it...
Old Oct 29, 2015 | 07:38 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Not the discussion I expected when I read the tile of this thread.
Old Jul 31, 2017 | 05:54 PM
nic48's Avatar
nic48
GET SOME SULASTIC SHACKLES!!!! NO MORE BOUNCE
KYLE302
Apr 25, 2025 04:50 PM
IHateCommieCars
Jun 14, 2018 11:27 PM
Scrpmny
Dec 13, 2015 06:21 AM
Daewoo
Feb 1, 2012 01:00 PM
Donald Rohret
1983 - 2012 Ranger & B-Series
Apr 11, 2004 06:57 PM
