try the master cylinder fix first, i had spongey crappy brakes ever since i bought the truck new and i just did this two weeks ago and its a night and day difference. https://www.ford-trucks.com/forums/7...rake-feel.html
whats wrong with your brakes anyway? soft, spongey, weak? and i dont think they fixed this yet because i've found this thread on the 97-03 f-150 section, the 04 and newer f-150 section and in the diesel section, so i dont think ford fixed the simple five minute adjustment yet.
Yea, I know its alot of work. Im hoping to find somebody with an adapter bracket to mount bigger on what I got. I dont mind the little bit of extra weight im going to gain.
Also I have the KR 20's so I would think they would have enough clearance
again r the brakes soft then? meaning you have to press them down far for the truck to stop? if so do like i said before and turn the adjuster bolt out one turn and you'll see how much better the brakes will get.
You could probably get pads that are more mettalic from someplace like napa and that would be a quick cheap improvement but it will eat up the rotors faster. I tried it on my '08 and it grabbed better but I got a little shimmy in the steering wheel from the stock dampener not being heavy enough so I put the stock ones back on. I have since found a better steering dampener but I haven't tried the mettalic pads with it yet.
Unless you are hauling/towing really heavy loads, I can't imagine that the OEM brakes are not sufficient. However, if you have the $$$ to spend, here is a thread with aftermarket options.
I wonder if you're experiencing what I call the vacuum-boosted brake problem?
Vacuum boosted brakes always felt soft and mushy to me. WAAAAY too much pedal travel to get the things to work; in a game where fractions of a second count, the half-second spent sucking up the "slack" in a vacuum booster means that it feels like it's not stopping as fast.
Hydroboosted brakes feel much more firm to me, and "work" much better. I can stand my 2007 on it's nose; it easily stops shorter than the 1/2-ton chevy that it replaced, at nearly twice the weight. Indeed, I can nearly take my own head off with the seatbelt in the Ford in a power-stop. Can you say, "arrestor hook"?
(I'm a bit biased because I'm used to air brakes; their feedback is much closer to a hydroboost system than a vacuum system.)
(this is one of the reasons why I'm so "cool" on the new '11's, even with the outstanding 6.7 engine: no hydroboost in the 250's.)
The foundation brake system, I can't IMAGINE it not being "big" enough to stop that thing.
Since you're still well within warranty, you might take it to the dealer and see if they'll bleed the brakes again... It's possible that they didn't get all the air out during final assembly.
