Injector pump??
Old Jan 15, 2011 | 11:59 AM
regidog's Avatar
regidog
Injector pump??
Have a fuel leak, looks to be from the passenger side but i am not sure at this point. Where is the injector pump located on a 92 7.3 idi none turbo? thanks fellas.
Old Jan 15, 2011 | 12:25 PM
Lazy K's Avatar
Lazy K
The injector pump is in the V at the front of the engine just behind the oil filler housing. The fuel lift pump is on the pass side front of the engine just above the oil pan joint.
Old Jan 15, 2011 | 12:51 PM
regidog's Avatar
regidog
Found both thanks.
Old Jan 15, 2011 | 06:29 PM
BlueOvalBud's Avatar
BlueOvalBud
Can you trace the leak? Could be coming from the injectors or from the rubber hose running between the injectors, that's the return line. Don't touch these and disturb them! This will move the o-ring that's on the injectors and cause a fuel leak for sure.
1983/84f350
Mar 22, 2012 08:15 AM
doorstop
Oct 25, 2010 11:16 AM
SAltonS
Dec 18, 2009 08:36 PM
f100guy
Jun 22, 2006 08:28 AM
jboard
Apr 24, 2005 02:56 PM
