NEED HELP
Old Jan 15, 2011 | 10:20 AM
jacobsjennifer10's Avatar
jacobsjennifer10
Question NEED HELP
does anyone know what relays are in the back of the explorer by the jack? there is a space for 6 relays but only 5 are there. i can not get my battery to stay charged and i heard one of these relays ticking, and one under my steering wheel also. well i pulled the one in the rear out and the ticking stopped all together. does that mean i have a ground somewhere or alternator bad maybe??? was there not enough juice to pump the relay so it ticked???
Old Jan 15, 2011 | 05:07 PM
shorod's Avatar
shorod
What year is your Explorer? Does it have ride height control (seemingly rare option)?
A ticking relay could easily be due to low voltage. Do you have a multimeter?
-Rod
Old Jan 17, 2011 | 11:23 PM
jacobsjennifer10
It is a 1997, and i have no clue if it has ride height control. i put new terminals on today and charged the battery ... hooked it back up and the battery light was on within minutes...what would be the easiest way to check if my alternator is bad?
Old Jan 18, 2011 | 06:51 AM
shorod's Avatar
shorod
The quickest way to get an idea if the alternator is bad would be to put a multimeter on the battery cables and check how much voltage the alternator is supplying with the engine idling, with the engine running around 2000 rpms, and with a load on the charging system (turn headlights on and blower motor to full speed). If you never see less than 13.5 Vdc through all those scenarios, or more than 14.4V, your alternator is probably doing its job.
The next step would be to use the ACV setting of your multimeter (or if you have access to one, an oscilloscope) and check for any significant AC component from the charging system.
-Rod
ncred02
6.2L V8
Feb 19, 2015 04:20 PM
davbeisner
Nov 16, 2012 05:08 PM
richardmiller
Dec 22, 2010 01:14 AM
west tn 6.0 powerstroke
Oct 26, 2009 10:19 PM
Wes64052
Feb 14, 2006 10:41 AM
