truck won't start
Old Jan 11, 2003 | 11:29 AM
sixx pak's Avatar
sixx pak
truck won't start
I turn the key all the way forward and it won't crank. I do have all lights,gauges,radio etc. Also if I use a remote starter to start it it will start. I dropped the column and took a look at the rod that goes to the ignition switch, and from what I can tell it is in good shape. I also removed the ignition switch from the column and tried to push the swich to the"start" position using a screwdriver. It physically moved to that position but did not start. I am thinking it is either the switch or the neutral safety switch. Does anyone know how to test either of these, or know what wires I should be looking for 12v at?
Thanks in advance.:-)
Old Jan 11, 2003 | 06:38 PM
RichB's Avatar
RichB
truck won't start
You may want to check out the starter relay first. That sounds like the symptoms my truck had when the relay went bad.
Old Jan 11, 2003 | 08:42 PM
sirtilealot's Avatar
sirtilealot
truck won't start
Old Mar 1, 2005 | 02:55 PM
86rustbucket's Avatar
86rustbucket
Sixx. I'm having a similar problem, did you ever find a solution?
I've already replaced the starter relay.
Is there is fuse or something from the igntion switch to the starter relay?
Old Nov 24, 2006 | 07:56 AM
stretch5881's Avatar
stretch5881
Chances are it is your nuetral saftey switch gone bad. Location varies as to the type of transmission.
1975FordF250
Aug 12, 2015 12:12 PM
Action410
Jan 18, 2013 07:40 PM
BillC1009
Aug 12, 2012 07:53 PM
88'f150_300
15
Nov 13, 2004 05:51 PM
Kallie
1978 - 1996 Big Bronco
Jul 1, 2003 03:07 AM
