Sponsored by: Real Truck
Wiper problem
Old Jan 14, 2011 | 06:56 AM
meanv10's Avatar
meanv10
Wiper problem
The other day i tried to move a large quanity of snow off my winsheild with the wipers, they got about half way and they stoped moving and started making this buzzing kind of sound.
So i removed the rest of the snow and they work until they hit that same point on the winshield and then the make that buzzing sound and i have to manualy pull them and they cycle until they hit that point.
Is it the wiper motor?
Oh and how do you remove the wiper arms?
Old Jan 14, 2011 | 07:12 AM
pbeering's Avatar
pbeering
Not a good way to learn the lesson about clearing the snow off first.....
The wiper arms are held on with a spring clip that attaches to the stud. If you are lucky, you just jumped the teeth on the stud.
Pull them off the windshield then with a small flat-head screw driver pop the retaining clip out (it should move about 1/16") See if the studs are stripped.
Then check the linkage to see if you tweaked it. Wiper motor is on the firewall and the wiper linkage is attached to it and the studs.
Old Jan 15, 2011 | 08:36 AM
meanv10's Avatar
meanv10
I took it all apart and what happened was there is a plastic gear that is turned by a worm gear on the dynimo and the plastic gear had the teeth chewed off of it so i had to replace the whole thing.
thanks for the help
phoneman91
64
Feb 2, 2025 05:40 PM
breadstick
1997 - 2003 F150
13
Dec 30, 2012 05:40 PM
Car Guy
Aerostar
Feb 18, 2010 12:02 PM
DeepRoots
Aug 3, 2005 07:15 PM
aerocolorado
Aerostar
Mar 11, 2002 10:16 AM
