This may be a very basic questions
Old Mar 7, 2003 | 10:58 AM
kikoba's Avatar
kikoba
Hi,
I am looking to purchase a 2004 MY Ranger in a few months, and I have one question. I've read some of the posts regarding diesel engine swaps, but I was wondering if I could get some concrete info. In a very basic sense... what is entailed in swapping out one engine for another? What engines are swappable? What do I have to watch out for? How do I know if an engine is compatible? Any recommendations for mechanics in Los Angeles that could do the swap? Does it make a difference whether it's a 4X2 or 4X4? Basically... I want the modern Ranger... but I want it to be a diesel... for various reasons. Like I said... these may be very basic questions and not worth your time... but any help you can send my way would be much appreciated.
Thank you in advance,
Trip Gould
Old Mar 8, 2003 | 09:37 AM
tomw's Avatar
tomw
FoMoCo is threatening to bring out a diesel in the NEAR future. Check the info at http://www.blueovalnews.com/ as they have some dope from the factory.
Other than that, swapping a diesel is probably easier, at least older diesels, as the emissions controls were lots simpler. The newer diesels, however, have similar emissions controls to the gasoline engines. In the '80s you could get a factory diesel in a Ranger. May have some info on that elsewhere on this web site, but there are also diesel sites on the web.
Details on a swap depend on the engine... will it bolt up to the bellhousing, fit the mounts, clutch linkage or hydraulic, throttle link, fuel connections, lift pump in the tank, and pressure pump for the injectors .. somewhere. Same stuff as a gas engine swap, but more difficult in some respects because they are not available and no one else does them. Would be great for other areas of the world, or if you lived on a farm and drove only on your own property to avoid the motor vehicle fuel tax (totally legal). Lots of torque if you got the right engine...
tom
Old Mar 8, 2003 | 12:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
Paying someone to do custom work is VERY expensive. Unless you have the experience to do the work yourself be prepared to just hand over your wallet. The mechanic will laugh all the way to the bank...
Old Mar 9, 2003 | 12:39 AM
79Lariat's Avatar
79Lariat
I'm no expert on this subject, so I have to ask one question. Is it legal to swap gas for diesel on an emissions controlled vehicle, especially in CA.? Seeing how there is no diesel Ranger being produced at this time, it might be hard to pull this off.
Steve Fielding
Engine Swaps
Dec 29, 2016 06:06 PM
lookabronco
1983 - 2012 Ranger & B-Series
Jan 13, 2016 07:34 AM
KngJn
Mar 18, 2015 05:56 PM
GFYS
1997 - 2003 F150
Apr 25, 2012 10:26 PM
ManfredVonRichtofen
24
Feb 26, 2012 08:59 PM
