Sponsored by: Real Truck
Wire Harness
Old Mar 18, 2015 | 01:28 PM
KngJn's Avatar
KngJn
Wire Harness
OKAY, I am new to the forum, and new to Ford all together.
I have searched and searched, and cannot get the info that my friend and I need.
We are doing a cab swap on a rollover 2005 F250 XLT SD 6.0L Diesel.
The question I have is, what wire harnesses are used for what packages?
Ex. Lariat VS XLT wire harness. What, if any is the difference between the two?
We're looking to swap a Lariat cab onto it, because he wants the options from the Lariat, but if we do what kind of problems could we run into electrically? Will we need a Lariat harness or the XLT harness will work? I basically need to know if the wire harnesses are option/trim/edition specific.
Old Mar 18, 2015 | 05:56 PM
05F250DSL's Avatar
05F250DSL
If you buy a cab from the lariat with the dash and its a diesel you should have most everything you need. The gas and diesel harnesses are different for the dash and instrument cluster I believe. The only other way to check would be to check into buying each at an online sites and compare part numbers.
dieseldodgeguy
Aug 1, 2013 07:18 PM
turbochargedford
Jul 27, 2010 10:03 AM
77 ford shortbed
Jun 15, 2008 08:29 PM
