guage questions
Old Jan 16, 2011 | 07:22 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by kx125str99
and also when using the pyro guage what should the temp not exceed while towing?
International says the 7.3 can handle 1250 degrees all day long. I've seen 1350 for a short while while towing and haven't had any issues. These are pre-turbo temps.
Old Jan 17, 2011 | 08:42 PM
kx125str99's Avatar
kx125str99
ok thanks. sorry im new to this gauge heat what is the trans temp supposed to be around?
Old Jan 17, 2011 | 09:33 PM
Shake-N-Bake
We generally like them as cool as possible. 60-80 degrees above ambient seems about average for a well cooling system. The factory trans cooler is pretty poor so I always recommend a supplemental cooler. Some have installed the 6.0 cooler with satisfactory results. I have a TrueCool that works well. There also is the TrueCool Max out now that looks good as well. Towing really heavy loads will increase your temps, especially in stop and go driving. If you can stay at or below 190 then you should have a long lasting transmission. Try and avoid 220 degree temps if possible and pull over if you see anything near 250-ish. If you do have to pull over, put the trans in park and increase the idle speed slightly until the trans temps cool down.
Happy towing!
Old Feb 3, 2011 | 08:08 PM
kx125str99's Avatar
kx125str99
well i finally received my gauges (boost, trans, pyro.). and was wondering if anybody had any helpful advice for installing. thanks
Old Feb 3, 2011 | 08:32 PM
bcaughhorn's Avatar
bcaughhorn
which gauges did you get?
Old Feb 3, 2011 | 08:39 PM
binuya's Avatar
binuya
Some small variations depending on which brand of gauges you got, but here's a good place to start: Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
Old Feb 3, 2011 | 09:24 PM
kx125str99's Avatar
kx125str99
i got the auto-meter z-series gauges
Old Feb 4, 2011 | 07:05 AM
Ponyboychris's Avatar
Ponyboychris
They are pretty straight forward as installs go. Printout Alvin's link from Dieselmanor and you will be set.
lartross
Feb 28, 2014 06:31 AM
Rich in CO
15
Mar 22, 2009 08:39 PM
redneckboy
Dec 4, 2007 01:06 PM
preppypyro
Jun 7, 2007 10:41 PM
