guages
Old Jan 12, 2011 | 03:13 PM
msisak's Avatar
msisak
guages
I bought a used 95 F150 with the 4.9. I really am not familiar with Fords and have a few issues. The spedometer and odometer do not work, there is no spedo cable. and now after hitting a bump, my fuel guages has stopped working. I have two tanks and two sending units that both worked before the bump so I cant see it being that. Any advice?
Old Jan 12, 2011 | 07:05 PM
Hunt4Fun's Avatar
Hunt4Fun
Sounds like it is time to have a look behind the instrument cluster. The connectors to the gauges are on 3 wiring harnesses. You may find that one of the clips that holds the harness in has broken and now the contact with the gauge is intermittent or separated entirely.
Old Jan 12, 2011 | 09:46 PM
TexasGuy001's Avatar
TexasGuy001
Check to see if the VSS on top of the rear axle is plugged in.
Old Jan 12, 2011 | 09:50 PM
fordsrawesome's Avatar
fordsrawesome
ya man I don't think ya have a big problem, sounds like just a loose connector or possibly a hole in the wire coating, and it grounded out. I have a 77 f250 that does that kinda crap sometimes I have yet to find where it is exactly coming from but I don't drive it much anyway
Old Jan 13, 2011 | 03:14 AM
xxshine's Avatar
xxshine
Missing the speed cable ? Go digital. Just a couple of wires to run up to the front. Of course that means messin with the stock look at the dash, but a custom gauge panel fixes all that, and then add some more digital stuff. There are tachs out there that are only 2 1/4" O.D. at the gauge face.
Old Jan 13, 2011 | 09:39 AM
xxshine's Avatar
xxshine
I have the old speedo cable & complete gauge panel from a 89 F 150 just sitting, taking up space. It's for sale.
fivepointohno
Oct 12, 2012 03:24 PM
lbrauer
18
Oct 24, 2010 04:01 AM
martink01
Electrical Systems/Wiring
Aug 10, 2010 09:48 PM
drumman1225
Aug 2, 2005 05:50 AM
Josh79
Jun 15, 2004 11:18 AM
