Chat with an Engine Development Specialist
Old Jan 18, 2011 | 02:19 PM
johndeerefarmer's Avatar
johndeerefarmer
What have you done to the ecoboost to prevent carbon buildup that effects direct injection gas engines?
How much build up was in the torture tested ecoboost?
Old Jan 18, 2011 | 02:21 PM
johndeerefarmer
Is a 36 gallon tank available with the ecoboost? If so, in what configurations? When will it be available?
Old Jan 18, 2011 | 02:22 PM
johndeerefarmer
Is Ford using the new SAE draft towing standard for the 2011 F-150 ratings?
Old Jan 18, 2011 | 03:55 PM
joiseystud's Avatar
joiseystud
Here is some info on 36 gallon tank availability in Supercrew. Hope it helps.
https://www.ford-trucks.com/forums/1...ml#post9842352
Old Jan 18, 2011 | 05:37 PM
akalogan's Avatar
akalogan
If ford is not using the new SAE ratings, how do they get the ratings as high as they do?
Old Jan 18, 2011 | 06:34 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by Hobo
Phil,
Any chance the new 5.0L might be adapted to an EcoBoost application in an upcoming Super Duty, perhaps as a high torque and horsepower alternative to increasingly expensive and complicated diesel engines and exhaust treatment systems? Just curious if it would even be a worthwhile project or if costs of both the theoretical engine would be too high. Would such an engine still achieve decent fuel economy, or is a diesel a better option even at a significantly higher unit cost for the engine?
Packaging wise the 5.0 doesn't fit under the Mustang's hood with 2 turbo's.
But it does with a blower
(think next GT500...)
I would anticipate any future power-trains to work across multiple platforms.
http://www.fpv.com.au/fpv-range/gt-p/overview.aspx
Old Jan 19, 2011 | 10:11 AM
astraelraen's Avatar
astraelraen
I would like to know the answer to this as well. ALL previous direct injection gas engines I have seen have carbon build up problems that can occur fairly early in the life of the engine. I've seen some horror stories (w/pictures) of VW/Audi DI engines, as well as Mazda DI engines.
Old Jan 19, 2011 | 10:13 AM
pfabien1's Avatar
pfabien1
EcoBoost - Ford
Originally Posted by joiseystud
FIrst thank you Phil for taking the time to talk to us. I am really excited that Ford seems to be getting into turbos in a big way. I just cant wait to see the Ecoboost V6 in an Expedition soon. Anything you want to announce about that? Just kidding. Can you talk about intercooling for the Ecoboost? Is there an intercooler?
The Ecoboost F150 uses an air-to-air intercooler that is mounted in front of the radiator so that it gets fresh air first.
Old Jan 19, 2011 | 10:19 AM
pfabien1's Avatar
pfabien1
EcoBoost - Ford
All gasoline engines have carbon build-up on the piston and combustion chamber. Typically PFI engines have less build-up in the intake port because the fuel spraying in the port helps clean it. For DI engines it is critical to minimize the amount of particulate matter generated during combustion to minimize intake port deposits. We have worked diligently to minimize the particulate matter generation in the Ecoboost F150.
Old Jan 19, 2011 | 10:22 AM
pfabien1's Avatar
pfabien1
EcoBoost - Ford
Unfortunately I am not familiar with the various vehicle configurations. You should be able to find that information on the Ford Vehicles website.
Old Jan 19, 2011 | 10:40 AM
pfabien1's Avatar
pfabien1
EcoBoost - Ford
Originally Posted by 640 CI Aluminum FORD
My question does not pertain directly to the Ecoboost, however I do have a question about what the Ecoboost means for future engines for the F-150.
I understand that with stricter C.A.F.E regulations coming in 2016 Ford has to make the F-150's more fuel efficent by any means required, be it by weight reduction and/or engine type. I know the Ecoboost is a great running engine as I have personally had the chance to drive one and I walked away very impressed with it. However despite this, I still perfer the 5.0L V8 (which I have also driven) to the Ecoboost as it just feels more like the right engine for me. I will be ordering a 5.0L FX4 this comming summer.
I know you can probably only speculate at this point,
But my question is, In the future, say 2016 and beyond will the F-150's V8 engine's live on? Or will they be phased out over time by smaller turbocharged V6's and I4's? To my understanding the F-150 is due for a re-design around 2014 or 2015 which could possibly intel substantal weight reductions in favor of fuel econmy, and I would love to see both 5.0L and 6.2L live on even after the strict emmison laws take effect. From what I can see, both 5.0L and 6.2L could benefit from direct upgrades such as Direct Injection and/or Turbocharging. From what I can see The 5.0L is already close to what the Ecoboost gets in terms of fuel econmy in both EPA rated and Real World (Judging based off the Fuel Econ display in both trucks). So it seems completely do-able from my perspective, however I would like to get your thoughts on it too.
Thanks for helping devolpe the greatest truck on the road!
Thanks for your time
Nathan.
Nathan, thanks for your question and support of Ford Motor Company. Unfortunately, we do not discuss future program plans that have not already been announced.
Old Jan 19, 2011 | 11:44 AM
Hobo's Avatar
Hobo
I wasn't asking about the Mustang.
Old Jan 20, 2011 | 06:45 AM
  #28
tseekins's Avatar
tseekins
Veteran: Coast Guard
Phil,
Welcome and thank you so much for your answers to this point. I'm truly not concerned about the EB's long term performance as I strongly believe that it will lead Ford well into the next generation of trucks and SUV's.
My question is more transmission related. Based on what I've read and heard, I'm assuming that all F-150's will use the same transmission.
If not, could you please explain?
If so, will this transmission go the distance with the 3.5L EB engine?
It looked as though during the 150K mile laboratory testing, there was no transmission attached to the engine. After the lab tests the engine was mounted into an F-150 and then into a Baja truck. Were different transmissions used for these two trucks?
The transmission is really my only concern. Very shortly I will be getting a 2011 F-150, not sure if I'm getting the 5.0L or the EB.
Thank you sir for your time,
Old Jan 20, 2011 | 10:41 AM
  #29
pfabien1's Avatar
pfabien1
EcoBoost - Ford
I semi-understand the physics of DI turbocharging... if you have a smaller amount of mass to turn (3.5l vs 5.0l) it takes less energy to do it, and it is more efficient.. but I am skeptical of the Eco part of the name. I owned a Mazda CX7 for a few years which had the 2.3l 4 cylinder direct injected turbocharged engine.
While that engine wasn't marketed as Eco anything, it got pretty poor gas mileage. The main "problem" the CX7 had... and in my opinion all the newer turbocharged engines have, is that boost comes too soon. From my experience, if you are in boost, you are getting poor gas mileage.
The ecoboost engine makes boost at such a low RPM, how are you going to stay out of boost, and thus get good gas mileage? The CX7 was in boost all the time, whether you were putting along or driving down the freeway, you were in boost - and its mpg suffered greatly.
For comparison sake, I traded in our Mazda CX7 AWD, it weighed 3800lbs and had a 2.3l 4 cylinder DI turbo engine for a 2009 F150 Crew Cab 4x4 with the 5.4l engine. The two vehicles get almost the exact same mpg.
What is Ford's experience with actual mpg figures for the ecoboost engine and how did Ford solve the problem that I seem to have experienced above?
I can not address the CX7 issue directly, but it is my uderstanding that the vehicle needed to run rich of stoich even at low rpm. The 3.5L Ecoboost engine can run at stoich even at full torque in low rpm range. It is a combination of many design factors that control when an engine has to enrichen and we worked to optomize the engine to maximize the speed and torque range that it can run stoich.
Old Jan 21, 2011 | 08:50 PM
  #30
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Hi Phil! Long time, no see!
