Thats pretty cool!
I'll bet its heavy. Years ago I had a similar engine, I owned a 1942 American LaFrance fire truck with a V-12. The engine are very similar, very narrow V's. On the American LaFrance engine the heads are broken up into smaller units; 1 for every 2 cylinders. The engines had 2 completely seperate ignition systems. One distributor power by the camshaft and the other coming off the crankshaft. You could run it on either one or both.
Here's a couple of pics;
I love those old Fire Trucks. I'm still just a kid playing with trucks in the dirt haha. I wish I had the resources I could realy go for a build like this. But for me too much heavy lifting and heavy spending. Someone can do it. Thanks for posting the thread.
Thats pretty cool!
Whoa, i've never seen heads like that before, very cool.
Thats pretty cool!
Wow Bobby, thanks for posting those pics, brings back memories. About 25 years ago I took on the challenge to build one of those engines that a few of the firemen had disassembled and ordered all of the needed parts. Took me a while to figure out where it all went, but as far as I know, it is still running.
I never got that one running. It was locked up. I pulled one of the heads off to check it out. Basically the part that looks like the head that the spark plugs are in is only a combustion chamber cover. You can't see directly into the cylinder, there is another "head" that covers the tops of the cylinders and there was an approx 3" by 1/2" slot up into the combustion chamber.
Since I only had rust in one cylinder I took approx 18" of 3/8" cable and frayed one end of it, then I could slip it through the slot into the cylinder and spin it with a drill. Between running that homemade wire brush in the cylinder and some penetrating oil I finally got the piston to move a little bit.
Unfotunately I ended up having to move to a smaller place and I couldn't take the fire truck with me and had to sell it before I ever got it turning over smoothly.
