35" mud terrains
Old Jan 12, 2011 | 05:27 PM
  #31
Ben82's Avatar
Ben82
then i wont be able to show off the cancer she has haha
Old Jan 12, 2011 | 05:59 PM
  #32
Ben82's Avatar
Ben82
an idea of what i think it will look like with the 3" blocks and 35s
Old Jan 12, 2011 | 08:21 PM
  #33
zxwut?'s Avatar
zxwut?
bwahahahaha!
You're not going to seriously go through with this, are you?
You are aware that it's going to impact your gear ratio and speedometer drastically, right?
Old Jan 12, 2011 | 08:30 PM
  #34
NW 150's Avatar
NW 150
Originally Posted by Ben82
I have the 351 and i mainly just want the mud tires so I can get more traction in the mud me and my friends like to go a lot and i want to throw more stuff around and hopefully not get stuck as often if i sold these and bought a set of 33's would that be better?
save your money and buy a truck specifically for off road use. problem solved
Old Jan 12, 2011 | 09:00 PM
  #35
TexasGuy001's Avatar
TexasGuy001
Thats alot better, but still not something I would do. I think that 32 11.50 would be better.
Old Jan 12, 2011 | 09:02 PM
  #36
TexasGuy001
Now i'm leaning towards 2" or 3" blocks for the rear and maybe some front coil spacers so its not extremely raked
If you go with rear blocks get some 1.5 inch ones that have the pinion correction angle. Fabtech makes them. Do not get aluminum ones. For the front get leveling coils not spacers. This combo will lift the whole truck a little and still have the factory rake to it. I would do this and run 32 11.50 on all 4 wheels. I actually had my truck like that for a while. I'll look for that picture. I took it all off because it does so much better in every aspect with stock suspension and 31 10.50.
Old Jan 12, 2011 | 09:19 PM
  #37
OGRE81's Avatar
OGRE81
This has to be a troll thread
Old Jan 12, 2011 | 11:06 PM
  #38
93Fodge's Avatar
93Fodge
Look at his "jack point" and then ask yourself if you really think he actually cares about those minute details?
Really, just wow, so much fail wrapped up in one thread
Old Jan 13, 2011 | 08:44 AM
  #39
NW 150's Avatar
NW 150
HAHAHAHA
Old Jan 13, 2011 | 03:56 PM
  #40
Ben82's Avatar
Ben82
oh i never thought about the gear ratio that would be more money than its even worth as much as i like those 35s i think i am going to sell or trade them and just go from there.
what would be better 31s or 33s if i got 31s would they be able to clear the rear without any modification?
i believe they're only 2" bigger than the stock tires
Old Jan 13, 2011 | 04:05 PM
  #41
zxwut?'s Avatar
zxwut?
Stock is cheaper. Go stock and save your money for gas and school.
Old Jan 14, 2011 | 12:36 AM
  #42
skyfox10's Avatar
skyfox10
31"s are just a hair over 2" larger than the stock 28.8" tires. Realistically 33" tires should fit on the rear of a stock 2wd truck without problems. I've heard some 2wd truck guys say they can fit 31" tires on the front and others say they cannot.
I'd say try to fit 31's all the way around. If the front doesn't quite fit, give it a minor lift. I don't know anything about 2wd front ends, but if they are like 4x4s, you can stack washers on under the spring cup to get an inch or so of lift up front. I did this on my old truck and after getting realigned, it worked just fine. The best option would be different springs, but if you don't have the money for springs, don't waste money on aftermarket spacers that do the same thing a stack of washers can do.
Then find a really cheap locker or at least swap the rear end from a junkyard truck that has a limited slip. It will still look halfway decent and do good in the mud for a 2wd truck.
Old Jan 14, 2011 | 10:40 AM
  #43
47ltb's Avatar
47ltb
Those 35's on the rear look to be a "bit much".
Think about 33's in back and 31's in the front, the truck will set a little better. That's what we had on a 78 2wd and it worked good.
Old Jan 14, 2011 | 03:05 PM
  #44
LARIAT 85's Avatar
LARIAT 85
I'm trying not laugh, but that just looks FUNNY!
Are you SERIOUS? If that thing as so much hits a pebble, it is going to hit the fender. Why would anyone want to put 35" tires on a 2 wheel drive truck?
AllAboutDaZ
Jul 29, 2015 09:23 PM
JWC 3
22
Apr 14, 2014 06:58 PM
Kirbys73F100
All Things Towing
Apr 29, 2012 09:26 PM
joe69
Jan 17, 2008 09:37 AM
DosMas
Sep 29, 2005 11:23 PM
