35" mud terrains
Old Jan 11, 2011 | 06:24 PM
Ben82's Avatar
Ben82
as it sits right now the suspension and tires are totally stock
Old Jan 11, 2011 | 07:11 PM
SouthernBlues's Avatar
SouthernBlues
The 35.s will fit with a body lift. My truck is 2wd and i am running 35 BFG Mud Terrains
Old Jan 11, 2011 | 07:15 PM
Ben82's Avatar
Ben82
sweet how wide are yours mine are 12.5's and do you have pics are they on the front too?
Old Jan 11, 2011 | 08:46 PM
93Fodge's Avatar
93Fodge
Lets say just for a second that you COULD clear 35's on a 2wd, it is a VERY BAD IDEA to put 35x12.50's on the front of a 2wd truck for mud riding purposes. They are aggressive, and will grab soft mud. Since there is no power going to them, the tire will just stop and start skidding more than rolling. You're better off running a smaller street tread on the front.
Old Jan 11, 2011 | 08:50 PM
SouthernBlues
The tire size is 12.5x15x35. I have all the way around. You can see pics on my gallery
Old Jan 11, 2011 | 09:09 PM
Ben82's Avatar
Ben82
do you ever have problems with the front tires rubbing the fender anywhere?
Old Jan 11, 2011 | 09:23 PM
SouthernBlues
They rub just a little on the inside of the wheelwell if i hit a bump while the wheels are turned
Old Jan 11, 2011 | 09:28 PM
Ben82's Avatar
Ben82
ok thank you for the help
Old Jan 12, 2011 | 10:40 AM
F150bulletproof's Avatar
F150bulletproof
you could fit 35's in the rear and front with no rubbing at all except for radius arm which you cant do away with no matter how much you lift it..i ran my 35's on my truck for months before i got my lift...you just need to space your front bumper forward about 2 1/2" or so..
Old Jan 12, 2011 | 10:45 AM
F150bulletproof
not lifted not even close to rubbing
Old Jan 12, 2011 | 12:08 PM
6CylBill's Avatar
6CylBill
His truck is two wheel drive. It won't fit 35's stock. Think about it.
And SouthernBlues truck is rare. 95% of two wheel drives will not fit 35's wih just a obdy lift. His truck sits higher than normal.
Old Jan 12, 2011 | 12:33 PM
dclack's Avatar
dclack
...and hopefully not get stuck as often...
If you don't want to get stuck as often, then just get a 4x4 and put the 35s on it. And if you don't ever want to get stuck, then lock up the front diff. That's your best solution!
Old Jan 12, 2011 | 03:39 PM
  #28
Ben82's Avatar
Ben82
I would like to do that but this is my first truck and i'm actually hopefully getting my liscense tomorrow. Once i get some money saved up i really want to buy a diesel 4x4
I made my decision and i will just get 3" blocks i jacked up the back to see rougly what it will look like and i like it
Old Jan 12, 2011 | 05:21 PM
  #29
huggyb1972's Avatar
huggyb1972
Cut the fenders in the rear and lower it to sit level make it look real rednecky.
Old Jan 12, 2011 | 05:26 PM
  #30
zxwut?'s Avatar
zxwut?
drop the keys and slowly walk away...
