'05 Leveling Kit
Old Jan 10, 2011 | 11:27 AM
floydwall's Avatar
floydwall
Question '05 Leveling Kit
I ran across this CL posting this morning, hoping some of you guys might be able to provide some feedback.
04-08 ford f150 leveling kit
Is this all the hardware I'd need? Should I avoid buying used?
Thanks in advance!
Old Jan 10, 2011 | 11:31 AM
MCDavis's Avatar
MCDavis
I'm always skeptical of used suspension parts..like why did the owner take them off? What adverse effect did they have on his truck.
It's likely that he went with a full blown suspension kit, but it's just as likely that he didn't.
For the same price you can get NEW spacers from Hell Bent Steel and Autosprings on Ebay.
Old Jan 10, 2011 | 11:59 AM
Sako 75's Avatar
Sako 75
I have to echo Chandler on the "New for the same price." If you buy new, then you get exactly what you want, with fresh paint and new locknuts.
Old Jan 10, 2011 | 12:06 PM
floydwall's Avatar
floydwall
I was thinking the same thing, just wanted to get some others thoughts on it. I'll pass on these and scout out some new ones. Thanks again.
Old Jan 10, 2011 | 06:48 PM
ggwash21's Avatar
ggwash21
I bought Hell Bent Steel NEW for $85
Old Jan 10, 2011 | 09:45 PM
Quack Addict's Avatar
Quack Addict
I echo the other comments. Pass on this and just order new. Autospring is the same price with free shipping I believe. That is the kit that I have and the front sits slightly higher due to the shell on the back of mine. I am going to add a AAL or a torsion assist to my rear to level it back out.
Old Jan 12, 2011 | 04:59 AM
alaskatabby's Avatar
alaskatabby
HBS ftw... $69 shipped.. awesome kit, had it on my first truck and I am gonna get another one soon..
Old Jan 13, 2011 | 09:45 AM
floydwall's Avatar
floydwall
Thanks for the advice guys. Curious - did you guys go with the 2.5" kit or 3"?
I'm looking at HBS website right now, they have them priced the same so instinctively I'm thinking "bigger is better"?
Old Jan 13, 2011 | 10:06 AM
alaskatabby
I had a 2.5"on mine and it leveled it out perfect.. I would suggest measuring the difference between the heights on the tallest point on your wheel wells on a flat surface and going with the closest match rounded down becuase if you put enough weight in the bed it will drop your rear an you could end up nose up..
Old Jan 13, 2011 | 10:13 AM
HYPO's Avatar
HYPO
The general concensus here and other sites is that 2.5" is about the max that your ball joints will tolerate over time. I have a 2.5 AS in my 2008 Screw and Firestone air bags in the back. It seems that if you go 2.5" in a 2004-2006 you may not need a little lift in the back. But if you have a 2007-2011 a 2" will generally put you level, and if you go 2.5" you may need a taller block, an add-a-leaf, or bags to put you level. Hope this helps.
HYPO
Old Jan 14, 2011 | 09:15 AM
eghead's Avatar
eghead
Agreed with HYPO. Anything over a 2.5" will probably make your front sit higher than the rear plus it would cause a lot of strain on your ball joints due to the angle. I recently helped a fellow forum member install a 2.5" HBS on his '07 FX4, and it made it sit almost perfectly level. He is still thinking of getting a larger rear block so his rear won't sag when towing or hauling.
Do you have a 4wd or 2wd?
Before
After
Front Strut before and after
Front Height Measurement Before and After
Rear Height Measurement Before and After
Old Jan 14, 2011 | 02:06 PM
floydwall's Avatar
floydwall
It's an '05 4x4 (Supercab FX4 to be exact).
Really appreciate the pictures, thanks.
Cwatson
Oct 28, 2016 03:14 PM
Tirekicker
Jul 6, 2014 09:25 PM
builtfordtough13
32
May 20, 2009 06:17 PM
TexasGuy001
Jan 22, 2002 03:44 PM
