Fuel filter lines
Old Jan 10, 2011 | 01:05 AM
ludacris16444's Avatar
ludacris16444
Fuel filter lines
The fuel line going from the inline fuel filter to the engine keeps falling off. I believe it is the clip holding the hose on but I'm not positive. Has anyone else had this happen and what should I do to fix it?
Thanks, Tim
Old Jan 10, 2011 | 02:46 AM
Prozon's Avatar
Prozon
The quick disconnect clip could be broken. You should replace it. Or you could run a hose and use hose clamps.
Old Jan 10, 2011 | 09:00 AM
aguitarestv's Avatar
aguitarestv
thats what i did, put a bubble flair the fuel line, then ran a piece of fuel hose (with the blue center for the high psi) and double hose clamped it.
Old Jan 11, 2011 | 10:38 PM
Robertlog's Avatar
Robertlog
Here is an aftermarket market repair kit that worked well on my 91 F150:
Dorman 800054 Nylon Fuel Line Repairkit
Amazon.com: Dorman 800054 Nylon Fuel Line Repairkit: Automotive
Tim Matthews
Aug 31, 2014 01:52 PM
Roper53
Mar 11, 2008 03:13 PM
Don Tim
15
Feb 4, 2007 10:13 PM
Alvin Tim
Nov 30, 2006 09:26 AM
AbadDriver
Bronco II
Apr 27, 2003 12:19 PM
