I read a post quite awhile ago about purchasing fuel filters from International. I searched but couldn't find the post. Does anyone have info about this? I remember the post had the International part # and the filters were alot chaper. Any help is appreciated.
Here are the fuel filter numbers I have. These numbers are good for the 6.0L Power Stroke engine 2003 and 2004. For some reason I think the filter numbers are different for 2005 to 2007.
Fuel Filter:
Donaldson: P550527
Ford: 3C3Z-9N184-CA
Wix: 33599
International: 18471-70C92 (dual fuel element service kit for VT275, meaning both filters come with this part number including o-rings)
Racor: 3244-2C93
i get them from the local international store and i do have to provide the international number as they do not know what to do otherwise. The cost is around 35 bucks for the set of 2 filters. I've used the same filters for 2003 and 2007 trucks, I think that they are the same. They do fit the same, look the same and act the same, so if there is a different part number for the different years, I'm not aware of it.
cheapest I've found. competes with international's price. http://shop.ivalueinternet.com/shopd...duct_id/60.htm fwiw, I've used wix filters with no problems....that I know of. However, I stick to motorcraft/racor filters now.
