Tri Power Intake on Ebay
Old Jan 11, 2011 | 05:39 PM
maverickman514's Avatar
maverickman514
Originally Posted by F-250 restorer
So, Charlie, what is the alternative to webbers with that intake?
you COULD maybe drill the WEBER intake for EFI and run 3 double throttle bodies .... THAT would be a NIGHTMARE to tune... but talk about SHOCK FACTOR! lol
the pieced together triple manifold set-up, seems to me, would require all 3 carbs to run full time....
I THINK I may have a solution.... using the lower half of an EFI intake, build a bolt-on box plenum and mount the 3 carbs atop the plenum. then build a progressive linkage and block off the idle circuits on the 2 outer carbs, set up the prog linkage to tip the end carbs in at about 3000-3500 RPM and let the big dog eat... will be posting a rough draft pic of concept as soon as I manage to put the pictures in my head on paper..
Old Jan 11, 2011 | 06:25 PM
dustybumpers's Avatar
dustybumpers
sounds good, make all the corners round on the inside though.
ln844south
43
Dec 31, 2011 05:45 PM
BLADE35
Aug 28, 2011 06:41 PM
SteveBricks
Nova Scotia
17
Dec 23, 2010 06:04 PM
mikedeason
Apr 2, 2007 10:38 AM
Alanok
1983 - 2012 Ranger & B-Series
Apr 11, 2005 11:16 AM
