P1670 Code
Old 01-09-2011, 09:07 PM
Joelong258's Avatar
Joelong258
Joelong258 is offline
P1670 Code
This is the second time i have ran in to this code. My truck did this a few weeks ago where it would barely turn over with no white smoke coming out. I would stop and start leaving the key in the on position trying to crank it and it will finally start and blow a ton of smoke out then the idle clears up. I checked the codes and came up with P1670 again. Does anyone have a clue why im getting this?
Ive read it could be cps, weak batterys, etc. Batterys are just a month old and it only happens when it gets into the teens but not all the time.
Old 01-09-2011, 10:38 PM
Deluxe06's Avatar
Deluxe06
Deluxe06 is offline
4000 rounds a min
It means there's faulty circuit between the PCM and the IDM (injector driver module). you'll have to check the resistance of the wires between the IDM and the PCM. wiggle the wires while checking and check for spike in v or open. I also had dirty connection on my batteries cause this code as well.
tommyl
07-12-2017 06:12 PM
hotrodfeguy
12-06-2016 07:26 PM
Candi Dokey
08-15-2016 10:27 AM
stwhite11
11-24-2012 04:49 PM
johnt471
01-05-2010 09:00 PM
Quick Reply: P1670 Code
