Sponsored by: Real Truck
Is my 99 SD Lifted?
Old Jan 8, 2011 | 06:41 PM
WMNY's Avatar
WMNY
Is my 99 SD Lifted?
My rear appears to be a few inches higher than the front and there is a 2" or so block between the springs and the axle. I had started to check on leveling kits, but then noticed that a lot of your trucks have the same posture as mine. And since a leveling kit is readily available it seems to enforce my conclusion that a stock SD is higher in the rear.
Is there a benefit to install the leveling kit?
Thanks,
wm
Old Jan 8, 2011 | 06:56 PM
CraigOutdoors's Avatar
CraigOutdoors
This is true. Stock rear is higher than stock front.
Mostly just looks from what I know. Though I could be wrong, I don't know of any other benefit.
Old Jan 8, 2011 | 07:00 PM
Cluney93's Avatar
Cluney93
Leveling kits are usually just for looks and allowing a bigger tire combo. On a leveled f250 you can run 315s instead of the stock 265.
Old Jan 8, 2011 | 08:06 PM
capn kirk's Avatar
capn kirk
looks or bigger tire is the reason for the kit. most lift kits level the truck. 350 sits higher in the back than the 250 because it has a bigger block
Kdr358
Aug 31, 2016 03:52 PM
liquidlounge
WTB - Parts & other
Aug 19, 2016 09:11 AM
2014denimstreetglide
2004 - 2008 F150
Apr 3, 2015 06:57 PM
skooch
Mar 17, 2015 06:55 PM
WRHadam
Sep 25, 2009 03:20 PM
