Sponsored by: Real Truck
Last question on leveling lol
Old Jan 8, 2011 | 08:17 PM
Cluney93's Avatar
Cluney93
This is my last question on a perfect level. If I put f350 blocks in the rear of my 01 f250 xlt extended cab long box 5.4L and add a 2.5" leveling kit in the front will my vehicle sit level?
Old Jan 8, 2011 | 08:26 PM
redford's Avatar
redford
FTE Leadership Emeritus
Does it sit level now?
With your plan, you're raising the front end a little bit more, but it'd hardly be noticeable.
Old Jan 8, 2011 | 08:38 PM
brd7666's Avatar
brd7666
If the standard front leveling kit is two inches, then you are going one half inch over. If the F350 block is an inch taller(not saying it is) then the F250 block, then your back would be a half inch higher in the end. I think you should be fine. Just do the math. What is the difference between the two blocks, and what is the standard front leveling lift. Good luck.
