Gas question
Old Jan 8, 2011 | 04:57 AM
coofmaaan's Avatar
coofmaaan
Gas question
Ok so today I bought a 1968 F100 from a friend for $1750. Does it take unleaded gasoline well or will I need oil additive? It has the original 360 ci engine, if that matters.
Old Jan 8, 2011 | 05:24 AM
jowilker's Avatar
jowilker
Welcome to FTE, Pull it up to the pumps and fill it with the cheapest 87 on the corner. It'll drink it just fine with no issues. No need to mix snake oil in. That is the diet for my 66 with FE.
John
Old Jan 8, 2011 | 08:53 PM
seafire's Avatar
seafire
Coofmaan
I need to run the middle grade stuff for my truck to run right. If I use the low grade it pops, spits, and has a hard time in all around.
Old Jan 9, 2011 | 03:51 AM
jowilker's Avatar
jowilker
Originally Posted by seafire
Coofmaan
Your truck need tuning, my friend.
John
Old Jan 9, 2011 | 11:52 AM
akforceten's Avatar
akforceten
I run the cheapest 87 octane i can find . the 390 runs great no pinging or popping screams like a banshee down the road !
Old Jan 9, 2011 | 12:19 PM
seafire's Avatar
seafire
John, my truck is tuned and runs just fine. All am saying is that it runs better on the midle grade gas. If I have to run on the lower grade I do.
Old Jan 9, 2011 | 05:50 PM
jowilker's Avatar
jowilker
Not to argue, but your truck should run just fine on low grade, and if it does not usually some tuning is needed.
John
Old Jan 9, 2011 | 06:32 PM
CougarJohn's Avatar
CougarJohn
Try a tank of cheapo, run it empty, fill it with 91 octane and see what happens.
My experience is that the better quality gasolines can help a hard-starting problem.
Old Jan 11, 2011 | 06:16 PM
ibdpic's Avatar
ibdpic
Older engines needed lead in the fuel to keep the valve seats from failing. I had a 390 out of a 64 and run unleaded in it over 1 year. Engine was getting tired and needed a valve job.
Old Jan 12, 2011 | 05:14 AM
jowilker's Avatar
jowilker
Thanks for your input, we are aware of the time frame of this engine. There was no unleaded gas to be bought except for Amoco white back then.
I will qualify for North Carolina anyways.
John
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
