Sponsored by: Real Truck
Tire size
Old Jan 5, 2011 | 03:08 PM
kmonty2's Avatar
kmonty2
Tire size
I am getting a 2011 F250 crew cab with 18" wheels. I am thinking about replacing them with a bigger size. How and or will that affect the way the truck rides, the mpg, and towing. I like the higher stance but don't want to sacrifice a lot of gas just for the look. I am getting the 6.2. Also, anyone know what the biggest size I can go and still get a full turn without rubbing?
Old Jan 5, 2011 | 04:27 PM
redford's Avatar
redford
FTE Leadership Emeritus
Generally, on stock wheels your local tire stores won't mount anything wider than a 285 tire. Some may go to a 305.
Any wider or taller tire will give you worse fuel mileage, due to increased wind and/or rolling resistance.
Old Jan 5, 2011 | 04:40 PM
cubantech's Avatar
cubantech
I agree with this. Also if you go bigger your speedo and mileage will be off. So in order to fix that you either need to go to ford or buy a hand held tuner and adjust it your self.
Old Jan 5, 2011 | 04:49 PM
kmonty2's Avatar
kmonty2
I don't want the tire to stick out pass the sides, just make it a little taller looking.
Alanok
1947 and Older Ford Trucks
21
Jun 30, 2016 05:51 AM
Alanok
1966 - 1977 Early Broncos
17
Nov 24, 2012 07:40 AM
Flatdeck
British Columbia
13
Aug 23, 2008 08:48 PM
Alanok
Apr 11, 2005 11:21 AM
