"creaking sound"
Old Aug 18, 2003 | 11:48 PM
ThePheonixx2's Avatar
ThePheonixx2
"creaking sound"
i know this could be one of a million things but some new nsight would be helpful...
when i stop myu front end makes a creaking sound lke maybe sommething is overtght or too loose and bindng...i am lost cause everythng looks good and ALL the front end bushings are POLYURETHANE (radius arms, sway bars, endlnks etc...) HELP!
Old Aug 19, 2003 | 10:54 AM
Soulseeka's Avatar
Soulseeka
"creaking sound"
MAN! my '98 sport does the same thing. When you find out what it is post it! I'll be searching for the culprit too.
Old Aug 19, 2003 | 11:55 AM
mahughesnh's Avatar
mahughesnh
"creaking sound"
I have a '97 that does the same thing, but my son-in-law found the problem for me. It was the lower half of the steering shaft. It slides over the upper half and was dry, no lube left. I used some white lithium grease on it and it has been quiet ever since.
The symptoms were a creaking sound whenever I came to a stop or started off from a light.
Mike
Old Aug 19, 2003 | 12:47 PM
Soulseeka's Avatar
Soulseeka
"creaking sound"
That's excatly when mine does it. I'll take a look tomorrow and give it a try.
MUCH thanks.
Old Aug 22, 2003 | 01:38 PM
ThePheonixx2
"creaking sound"
cool i wll try that...i wonder if wd 40 wll do the same...
Old Aug 22, 2003 | 02:24 PM
mahughesnh's Avatar
mahughesnh
"creaking sound"
WD40 is what I used first to verify the location of the problem but it has no staying power. Too close to the engine I think. It just boils off in about an hour of driving. But the white lithium grease has worked better although in my case I am going to have to replace the lower steering column part because the rubber boot is torn. It is starting to grind a bit in the joint. But I think you will find that the grease helps with the creaking sound. It sure did for me.
Mike
Old Aug 24, 2003 | 12:49 PM
Soulseeka's Avatar
Soulseeka
"creaking sound"
give me more specifics on where you put the white lith grease.
my squeak seems to be elsewhere.
Old Aug 25, 2003 | 09:21 AM
mahughesnh's Avatar
mahughesnh
"creaking sound"
It was pretty simple on mine. Follow the steering column from the firewall down and you will find a lower shaft that slides over the top one. That is where my creaking was coming from. Maybe yours is caused by something else. I was just helping with my experiences. I am sorry if I did not offer a solution to your problem. I certainly did not mean to lead you astray.
Mike
Old Aug 25, 2003 | 11:31 AM
Soulseeka's Avatar
Soulseeka
"creaking sound"
Oh, no problem Mike, I appreciate your feedback, just more knowlegde for me. When I figure out where mine is coming from I'll post it.
Thanks agian
SSKA
firedaniel
Apr 4, 2015 06:31 PM
pgw85706
1983 - 2012 Ranger & B-Series
Mar 12, 2008 09:38 AM
mroberts
17
Oct 18, 2006 02:28 PM
KenFromNorCA
Mar 11, 2005 05:47 PM
vdaily89
Jul 17, 2004 08:00 AM
