07 powerstroke problem
Old Jan 3, 2011 | 04:20 PM
roostnu074's Avatar
roostnu074
hey guys heres the deal,
my 07 powerstroke just out of the blue started bucking and kicking while going up an upgrade. the turbo psi gauge keeps jumping and there is a weird sound coming from the engine compartment. on my way back to the house it just got worse. on a hill i hit at 85 i made it to the top at 45. big rigs were passing me. it was imbarrissing. i have no mods and only 127300 miles on it. it does get ran hard but dang. last oil change bout 2000 miles ago. what could be the deal???
Old Jan 3, 2011 | 06:27 PM
powerstroke72's Avatar
powerstroke72
Moved to 6.0L Powerstroke Diesel forum.
Old Jan 3, 2011 | 06:56 PM
smokersteve's Avatar
smokersteve
Do you have any smoke?
Oil leaks?
See if you can find a friend, auto store or shop that can pull up any codes.
Old Jan 3, 2011 | 06:59 PM
bismic's Avatar
bismic
any codes?
oops too slow ..
Old Jan 3, 2011 | 07:40 PM
IHbase's Avatar
IHbase
Why would you "hit a hill at 85" with a truck you know has a potentially serious mechanical issue?
-mike
Old Jan 4, 2011 | 05:41 AM
matty169's Avatar
matty169
HA HA HA.....
-mike
To try to make it to the top of course!!! What kind of noises? Pull the intake off the turbo and check the shaft for play, up and down, left and right and in and out. ALL GOOD? Well, pull your EGR valve and take a look at it. Plugged up is it? NO? Get codes and look for boost leaks. Stuck turbo, EGR valve, smoking? If smoking, what color and when. Im guessing bad turbo or needs to be disassembled and cleaned. Hope not! Close to Cheezit??? He can tell you whats up.
Old Jan 4, 2011 | 06:45 PM
cheezit's Avatar
cheezit
sounds like hanging / stuck turbocharger. possible egr concerns
94powerstroke
Oct 19, 2012 07:34 PM
Fat Cat Rider
6.4L Power Stroke Diesel
Apr 23, 2011 02:44 PM
Ford11
Jun 23, 2009 07:18 AM
guidry23
May 4, 2009 10:17 AM
tatorchip
New Member Introductions
Jan 30, 2008 02:35 PM
