Battery cables
Old Jan 3, 2011 | 01:37 PM
mabc926's Avatar
mabc926
Battery cables
Anyone ever make their own battery cables?
My truck needs some, and I don't want to pay the price for the already made ones!
Thanks in advance.
Old Jan 3, 2011 | 03:28 PM
oreocreaming's Avatar
oreocreaming
ya, its easy enough. get some bulk 0, 2-0 or 4-0 if you really got $ to burn lol and get 3 copper ends that you can crimp for the starter + and block - cables, then you want 3 terminal ends for the battery itself, and one pass through end for the + cable on the passenger side.
block grounds and starter end
pass through passenger side + terminal
drivers side + and both - terminals
check out http://copper-electrical-components...._terminals.htm
Old Jan 3, 2011 | 03:45 PM
greywynd's Avatar
greywynd
I may have a source for decent cables for our trucks, ordered one through a local supplier, and should be here tomorrow. Pricing should be about $90 Canadian, so might even be feasable to resell some to you guys if there's interest.
Old Jan 3, 2011 | 03:50 PM
oreocreaming
i got the pre fab one for the positive side, its junk! they are too short between the two batteries and the wire that runs to the fender wall solenoid came right out of the terminal.
Old Jan 3, 2011 | 03:56 PM
Tech89's Avatar
Tech89
Just curious, is there anything wrong with using some good marine terminals? Too much resistance or not stong enough for the application maybe?
-Pat
mabc926's Avatar
mabc926
I pretty much know what all I'm going to be using.
I'm either going to make it all out of 3/0, or I'm going to connect the two batteries with 2/0 and just use 3/0 to the starter (like factory for the 6.9 style)
And as for the ends I plan on using the wing nut style terminal (just in case a winch makes it's way on my truck )
I still like hearing everyone's ideas and suggestions though.
Old Jan 3, 2011 | 04:43 PM
oreocreaming
dont think ive ever seen 3-0 its always 0, 2-0 and 4-0. and i wouldnt go wingnut. id go standard top post for the starting power. way more contact area. you can get top and side post batteries so you can use the top post for your truck electronics and the sides for any accessories you decide to add on later. just my .02 though
Old Jan 3, 2011 | 04:54 PM
damac's Avatar
damac
I didn't even think twice using those marine wingnut type terminals with biggest lugs. I rewired our travel trailer with a 60 amp charger/converter and also an inverter that outputs at 2500+ watts peak.
I also did the truck all around because mine were rotted from the inside. I think everything is working ok?
I bought my stuff from genuine dealz online(search google). They have some bendier type larger wire, and the little pellets you can use with the ends and a torch. They also have some nice heat shrink you can hit the ends with.
Then get yourself some protective loom. I think if you price out things at that store you could actually go bigger on the wire and still save money over a ford part? And break things apart so you can take each run apart easily.
Old Jan 3, 2011 | 05:51 PM
catfish101's Avatar
catfish101
If you have 3/8 stud, go with them. Thats all class 7 and 8 trucks use. Thats the way to go. If you can get "welding" cable use it. The strands are finer. Carry more current....If you go with batts with 3/8 studs you can take one of the nuts. Knock the end out of it and run a 3/8 coarse tap all the way through it. Then you can stack terminal ends on top of the nut...I use copper jugs and crimp them then solder for to insure good contact. You can get by with it, most likely, on one of these trucks with out crimping but I have seen starters draw enough when trying to crank a hard cranking engine that the solder melted and the cables blew out of the lugs....Like the others said, 2/0 cable is fine. They make 3/0 but you don't need it....I know I can make them cheaper but I do have a friend that deals in Electrical supplies wholesale. That helps. KATCO Service Parts
Old Jan 3, 2011 | 06:17 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
iv been using the wing nut style terminals for over a year now.
whenever i need to add something its easy as pie.no problems at all.
stock is 2/0 everywhere.
stock up until the late 80's somewhere was 2/0 with 3/0 going down to the starter.
i went crazy and went tinned marine 3/0 everywhere lol.they will long outlive the truck,and possibly even go onto the next one.
Old Jan 9, 2011 | 04:02 PM
BlueOvalBud's Avatar
BlueOvalBud
I re-did my cables 2 years ago. I used the stock cables, cut the terminals off, soldered on copper lugs with a propane torch like you would do plumbing in a house, then heat shrinked the connection. OH, don't forget to slide your heat shrink on BEFORE you solder the lug on!! And move the heat shrink down to the middle of the cable because if you leave it too close to the work area, you might find it has shrunk too small to slde over the connection. Live and learn!
I am running marine terminals that are a 3/8" stud with a regular nut on top. I didn't use the wingnut becuase I wasn't sure I could get it tight enough to feel secure it wouldn't just rattle off.
I used a utility knife and slit the rubber cover so it just slides over the heat shrink and covers up most of the terminal area that's exposed. Not perfect, but it helps a little bit!
I didn't do the negatves because they are in pretty good shape, the only reason I had to do the positives is because that pass-thru terminal was all busted apart.
Old Jan 9, 2011 | 04:05 PM
FORDF250HDXLT
thats what i should do to mine as well.ditch the wing nut and use a lock washer and nut.the wing nuts do keep loosening slowly over time.i find myself checking them every time i pop the hood.at the least,i should just try a lock washer under the wing nut.that would probably work too.
Old Jan 9, 2011 | 04:20 PM
BlueOvalBud
I have a lock washer on the drivers side, but there's just not enough room to get a lockwasher under the passenger side...so I just crank on it and they haven't loosed up yet!
I had this set on my first truck, then the engine went, so I transferred it over to this truck.
AND, to make this setup cooler...it was recommended to me by the guy at Carquest where I buy all my parts because he still supplies parts to a guy who has a fleet of E350 vans with 6.9's that run freight...and so we go back and forth with ideas when I'm in the store.
78 & 87 Super Cab
May 20, 2014 04:27 PM
Frankiea87
Dec 26, 2013 04:40 PM
john fin
Nov 22, 2011 09:43 AM
Happyreefer
19
Nov 8, 2009 04:18 AM
BigShelby
Aug 8, 2003 01:06 PM
