Battery cut off switch
Old Jan 7, 2011 | 03:17 AM
k-member's Avatar
k-member
When I was drag racing a lot your cut off switch had to be mounted at the rear by the tail light or bumper in case of an accident or roll over and it had to kill the system of the vehicle. I had mine hooked up a few different ways and it would still run when you killed the switch. Thing is the alternator will keep every thing running as if you started it up and took the battery out, it was running on the alternator. Summit sells a kit to fix that and it's kind of pricey. The secret is to go to NAPA and get a one way diode (pt# 102-30 or 0144200E52) for 15 bucks and install it in the power out side of the alternator. Battery cut off and kill switch in one.
F1Hunter
41
Jan 2, 2016 03:38 PM
Niknik68955
2004 - 2008 F150
Oct 19, 2015 07:16 PM
Tyler S
Sep 7, 2014 01:32 PM
RhondaBruce
1983 - 2012 Ranger & B-Series
Mar 14, 2011 09:19 AM
seawulff
27
Sep 5, 2005 11:33 PM
