4wd popping
Old Jan 2, 2011 | 08:58 PM
fe8u's Avatar
fe8u
4wd popping
2001 sport trac
2hi,4hi,4lo transfer case
while in 2wd there are no weird noises everything normal
while in 4wd there is popping, banging noise while under a load been doing this for awhile now just getting extremely worst by the day
my thoughts are
transfer case bad?
front driveline cv joint?
or?
thanks for any replys
chad
Old Jan 4, 2011 | 03:55 PM
MCDavis's Avatar
MCDavis
What type of surface are you engaging the 4wd on? Pavement? Hard pack dirt? Snow?
If pavement or dirt, you might be getting drivetrain bind as there needs to be a little slip for the 4wd not to bind.
Old Jan 4, 2011 | 09:45 PM
fe8u's Avatar
fe8u
all surfaces( loose snow, hard snow, highway)
i'm going to remove front driveline and go from there
Old Jan 5, 2011 | 06:43 AM
MCDavis's Avatar
MCDavis
Probably not a good idea to engage it on dry and wet pavement. There is still too much friction there for the drivetrain to handle. A4wd is ok, but 4hi or 4low should only be used on the slick stuff.
Good luck with your problem solving. Definitely has a bind in it somewhere. Could be the half shafts and CVs on the front end.
Old Jan 5, 2011 | 07:47 AM
SEAL1's Avatar
SEAL1
If you are not seeing any anomalies in the 4x dash lights, I would look at those C/V joints. Is it worse in a turn?
Old Jan 5, 2011 | 04:12 PM
Moto Mel's Avatar
Moto Mel
It could be the planetary gear set or the chain my son had a similar noise in this Mountie. T/case was replaced under warrantee.
Old Jan 5, 2011 | 11:25 PM
fe8u's Avatar
fe8u
174000 miles, original drive train
no weird noises in 2wd, smooth as a baby's butt
front axles or half shafts, cv joint good
just in 4wd bang bang
Old Jan 6, 2011 | 05:28 AM
MCDavis's Avatar
MCDavis
Hmmm. I spun the bearing on the CV coming out of the transfer case on my 99 V8 AWD a few years back. It would drive, poorly, but would crack and pop anytime I accelerated. I was able to reach under the truck and physically move the front shaft with my hand some, whereas it should have zero play if all is good and well. I know the TC's are different, but it's still a CV coming out of your case. Just a thought.
Old Jan 6, 2011 | 10:23 PM
fe8u's Avatar
fe8u
so i took the front drive line out with out destroying anything
cv joint felt rough and would bind by hand when rotated
drove exploder around and switched between 2wd,4hi and 4lo
and no popping or banding
95% positive it is front drive line cv joint
Old Jan 7, 2011 | 05:26 AM
MCDavis's Avatar
MCDavis
You might want to search the junkyards for that driveshaft. The replacement on my 99 V8 from Ford was nearly $600 before installation. All said in done, in 2005, it was almost $900 to get me out of the dealership. Expensive day.
Glad that you found the problem. Good luck with finding a replacement!
WyattB7154
Bronco II
Jul 6, 2017 07:14 PM
Jarkill
Jan 12, 2017 12:52 PM
bmj26
Jan 8, 2017 11:38 PM
grizzlyjosh
Oct 6, 2016 01:18 PM
rockfarmer9
Oct 21, 2015 02:17 PM
