posi trac
Old Jan 2, 2011 | 02:11 AM
Fexx22's Avatar
Fexx22
Question posi trac
i have a 77 ford with a 302 and i want to swap the rear end to a posi-tract rear end....does anybody know what year/make and models i would find them ...thank u guys once again...all input is appreciated..
Old Jan 2, 2011 | 09:20 AM
410F-100's Avatar
410F-100
limited slip wasent exactly standare equpiment on most trucks and cars.
your best bet is hit the junk yard and look around till you start findin 4X4 dents and jack up the rear end and give a wheel a spin, if the other wheel spins in the same direction youv got limited slip.
then continue your search till you find one with the right gears for you, or at least close enough, as long as you arent 4X4
Old Jan 2, 2011 | 12:47 PM
HIO Silver's Avatar
HIO Silver
"Posi-Trac"? Blasphemy!!! .. that's bowtie-speak !!! Use blue blooded FTE'ers call it Traction-Lok!
First take a look at your rear end to see if it still has the axle tag. If so, there should be some numbers that many denote it has limited slip. For example, "3 L 50". The "L" means trak-lok. An open carrier would simply be "3 50".
Second, verify your rear ratio by counting how many turns of the driveshaft it takes to make one wheel revolution.
Third, axle splines... 28 or 31? Typically, these rigs use 31-spline axles. The best way to verify is to actually pull an axle and count the splines.
Measure flange to flange and perch to perch and take these measurements with you while you're axle hunting.
Old Jan 2, 2011 | 06:11 PM
Fexx22's Avatar
Fexx22
Thanks a bunch for the input im a newbie with this...i dont understand what a fte is and what is a dent?......
Old Jan 2, 2011 | 06:45 PM
Redneckryder's Avatar
Redneckryder
fte-ford truck enthusiast
dent-1973-79 ford truck....because of the "dent" body line running down the side of the truck
Old Jan 2, 2011 | 06:46 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Blasphemy!
FTE = Ford Truck Enthusiast
Dent = 73-79 Ford Pick-up because of the "dent" along the belt line.
Josh
Old Jan 2, 2011 | 07:09 PM
bmuhlbach's Avatar
bmuhlbach
Make sure you have a 9 inch rear end there is no cover or bolts on back of the rear.I had a 77 F100 with a 302 and it had a dana 44 rear end in it.They have a cover and bolts that hold the cover on the back side of axle or pumpkin.
Old Jan 3, 2011 | 02:00 AM
Fexx22's Avatar
Fexx22
Okay i understand what dents are now...lol...i got a dana 44 rear end its got a cover and its bolted on....i need to find one with no cover or bolts on the rear..gothca....i do appreciate the crash course...
Cope
Offroad & 4x4
20
Jan 21, 2016 07:46 AM
free72
Dec 19, 2014 06:21 PM
cstephens
Sep 10, 2014 11:16 PM
obx 79 shortbed
Aug 30, 2014 10:20 AM
1966blueford
Jul 8, 2001 10:50 PM
