Troubles with a '96
Old Jan 2, 2011 | 09:00 AM
oldbird1965's Avatar
oldbird1965
How much boost does it take before the PCM defuels? I used to know but forget.
Old Jan 2, 2011 | 09:08 AM
Muktown's Avatar
Muktown
23 psi. I have an adjustable regulater but can't seem to get it set right so I have one from clay on the way
Old Jan 2, 2011 | 06:10 PM
bulla's Avatar
bulla
He's running the truck with no gauges right now so I'm not sure what kind of boost or egt's he's running. We'll have to work on that! But thanks for the help. We did some searches last night on cutting out and most seemed to be cps related. I have an extra black one we might try for fits and giggles!
Old Jan 4, 2011 | 09:49 AM
bulla's Avatar
bulla
Hey Fob post up and introduce yourself!
Old Jan 5, 2011 | 08:01 PM
Fab's Avatar
Fab
Hey fellas, I'm Fab. I got the '96 with the wierd high end cut out. I did run the auto pcm at first, but changed it to the manuel which did fix the idling issue, however the cut out was there since the rebuild.
Old Jan 5, 2011 | 11:41 PM
Muktown's Avatar
Muktown
Welcome to fte Fab!
Easy test. Unplug the map and see if it does it. Im still thinking your pcm is defueling
Old Jan 6, 2011 | 06:18 PM
bulla's Avatar
bulla
Man I can't believe I misspelled your name! Did you try unplugging the sensor? And welcome to the great FTE!!
Old Jan 6, 2011 | 06:21 PM
bulla's Avatar
bulla
Oh yea another thing is this rebuild is from 4 years ago and been running like this since.
Old Jan 9, 2011 | 08:02 PM
Fab's Avatar
Fab
I unpluged the map like you suggested, no more cutting out and not as much smoke.
Old Jan 9, 2011 | 08:16 PM
Muktown's Avatar
Muktown
Good to hear it wasn't anything major! This shouod solve your problems
Riffraff Diesel: OCR - Overboost Code Regulator
Just double check with clay at riffraff to make sure the obs and superdutys both cut out at 23psi. Otherwise I have an adjustable one that I just took off my truck if your interested. Also get a set of guages if you can
Old Jan 9, 2011 | 08:56 PM
oldbird1965
This is the one I got, nothing against clay though!
http://www.dieselsite.com/index.asp?...PROD&ProdID=31
gopher2
Jun 1, 2014 09:11 AM
creator
25
Feb 5, 2012 07:21 PM
foxracing0934
Jan 29, 2010 10:58 AM
SVLERF250PWRSTRKE
Feb 6, 2008 06:04 PM
alkiOU
1983 - 2012 Ranger & B-Series
Jul 9, 2004 05:55 PM
