how to fix high idle?
Old Dec 31, 2010 | 07:15 PM
oldfordisbetter's Avatar
oldfordisbetter
searched and cant really find anything.. i kno check for vaccume leaks. what else can i look at or replace to solve my high idle woes? i want to put a flowmaster on it but it idles too high sometimes and it would be really embarrising with the high idle.
Old Dec 31, 2010 | 07:35 PM
jodaddy's Avatar
jodaddy
1st clean up the throttle linkage and make sure the butterflies are closed all the way. clean up the throttle body. if that dosen' t do it then try these: iac stuck open, tb gasket leak, if you still have the original plastic vacuum lines check all of them or just replace them with all rubber. tps out of adjustment.
Old Jan 1, 2011 | 05:26 AM
TexasGuy001's Avatar
TexasGuy001
I'll second what he said.
Old Jan 1, 2011 | 06:42 AM
oldfordisbetter
btw i have a 92 f250 5.8 4wd 5spd 145000miles
Old Jan 1, 2011 | 09:23 AM
DBGrif91's Avatar
DBGrif91
Have you tried pulling any codes?
Ford Fuel Injection » How To Run a Self-Test
bracyder
Feb 15, 2015 09:53 PM
Midnight Ride
6.7L Power Stroke Diesel
Jun 15, 2013 06:05 AM
vboxingguy
Apr 5, 2012 09:51 AM
JethroF250
Mar 5, 2008 06:49 PM
resipainter
Jan 31, 2003 04:31 AM
