idles too high
Old Jan 26, 2003 | 06:15 PM
resipainter's Avatar
resipainter
idles too high
hello my 95 f-150 is idleing really high and won't kick down. I changed the throttle positioning censor and still no luck. help
Old Jan 26, 2003 | 10:47 PM
Franklin2's Avatar
Franklin2
idles too high
Take the throttle body apart and clean around the throttle plate and in and around the IAC valve. Then try it.
Old Jan 31, 2003 | 04:31 AM
1-ton's Avatar
1-ton
idles too high
Which engine do you have? If it is a 302 there is good chance that your intake gasket that goes between the upper and lower pieces of the intake is blown out. I had the same problem on several different trucks with the 302, seems they have somewhat of problem with this. It is not very hard to change, but is a little time consuming. If this turns out to be the problem,and you replace it , make sure you use a good aftermarket gasket like Felpro as these seem to hold up better.
Gerryatrics
1997 - 2003 F150
19
Mar 30, 2014 06:11 PM
tneyman
Jul 23, 2007 02:22 PM
FORDWRENCHHEAD
Jan 7, 2003 02:52 PM
georgedavila
1978 - 1996 Big Bronco
Sep 18, 2001 07:54 PM
jopey
Oct 11, 2000 01:50 PM
