Tried out new Autoenginuity scanner pulled 3 codes
I read 48.5 volts for FICM main power so thats good right? Injector buzz test passed. Battery voltage with key on engine off was 11.28, maybe not so good?
I did pull 3 codes so now have to figure out how to fix.
Pulling System DTCs 5 of 9
+ Communication: 3
+ System: GEM/Central Timer
Reporting 3 DTCs
Code ID: 0x9483
+ Display Text: 'B1483 Brake Pedal Input Circuit Failure'
+ Code Type: Stored Code
+ Module: Manufacturer Specific
*** No Freeze Frame Associated with code ***
Code ID: 0x1876
+ Display Text: 'P1876 Transfer Case 2-Wheel Drive Solenoid Circuit Failure'
Code ID: 0x1832
+ Display Text: 'P1832 Transfer Case Differential Lock-Up Solenoid Circuit Failure'
the ODBII port. You might double check via Digital volt meeter
on the battery(s) to be sure the ODBII port is close to actual.
I get 11.6 - 11.8 with glow plugs on, and then 13.9 -14.1 engine running.
I don't recall the voltages glow plugs off, engine not running.
KOEOff (glow plug on, buzz, fuel pump on)
KOEOff (glow plug only)
KOEOff cranking
KOEOn running first 2 min
KOEOn after 5 minutes (when glow plugs off)
Then another measure after driving 15 or 20 min.
