AE 5.1.1 Posted
Old May 22, 2007 | 08:40 AM
cef2lion's Avatar
cef2lion
AE 5.1.1 Posted
I just noticed that AE 5.1.1 is posted on the AE Web site for download.
http://autoenginuity.com/downloads.shtml
Craig
05/08/2007 5.1 Release:
General
• Added support to show the hardware ID in case of mismatched hardware errors so the customer can determine which is connected currently to correct the mismatch
• Fixed the issue when no enhanced interface is created the system combo box does not contain any systems
• Fixed the issue when there is no valid AutoEnginuity Enhanced Interface serial number, only the firmware ROM version
BMW
• Fixed ABS MK60 not showing 5EXX trouble code descriptions
• Fixed ABS MK60 not working on the Z4 models
• Added Convertible Top Module 4 trouble code and PID support
• Added Safety and Information trouble code and PID support
• Added Electronic Power Steering trouble code and PID support
• Added Rain Sensing System PID support and Clear Adaptations system command
• Added Satellite-B Pillar Left trouble code and PID support
• Added Satellite-B Pillar Right trouble code and PID support
Chrysler
• Added 600+ U trouble code descriptions
• Added 500+ P trouble code descriptions
• Added 2500+ B trouble code descriptions
• Added 500+ C trouble code descriptions
• Added Freeze Frame display support for Non-PCode trouble codes
• Added a message when pulling DTCs for VPW body and chassis systems to tell the users that the codes are displayed as sensors
• Fixed pulling an extra DTC from CAN controllers
• Fixed decoding engine size and body code information from VINs being pulled generically
• Fixed an issue with duplicate Engine Speed PID in 2005 CAN NGC vehicles
Ford
• Added Injector Fault 9 and 10 for the Enhanced Powertrain CAN 6.8L models
• Added full system support for '04 - '06 SuperDuty 6.8L models
• Added Module ID support for non-CAN non-PCM controllers
• Improved all Crown Victoria sensor support for '96 - '06 models
• Fixed ABS Self-Test completing but not showing the DTCs for non-CAN controllers
GM
• Fixed incorrect sensors in the Body Information for the 2004 Truck K for HVAC
• Fixed an issue with transmission types specific to the Auto Transfer Case not showing up causing this system to be available
Honda
• Added PCM and transmission actuation commands support
• Added System Tests (where applicable):
Crank Position Sensor Notch Learn
DBW Throttle Carbon Clogging Status
DBW Throttle Carbon Clogging Reset
Engine Oil Replacement Reset
Off-Board EVAP Test (Level 2)
Resolver Zero-Position Offset Calibration
Hyundai/Kia
• Added more trouble code library support
Mazda
• Added text sensor reporting for all bit and mode sensors
• Added support to retrieve Mode 33 trouble codes on ISO controllers
• Added missing Protege 5 ABS and PCM for model years '01 - '03
Nissan
• Added Platina model support
<!-- / message -->
<!-- controls -->
Old May 22, 2007 | 10:21 PM
jtharvey's Avatar
jtharvey
Thanks for the update. I hadn't even upgraded to 5.0 yet. Looks like I'll be going straight to the newest version.
Old May 22, 2007 | 10:25 PM
John311t's Avatar
John311t
I have not upgraded either yet. I think ill wait it out, until the next one.
Old May 22, 2007 | 10:28 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Well, after some stumbling, I got my 5.0 working and while I have the 5.11 downloaded I've not yet installed. Is that an update or a whole new install. I still don't feel all that fuzzy on the answer I got last time I asked. I still have soo much to check/play with. Alan????
Old May 22, 2007 | 10:36 PM
John311t's Avatar
John311t
How ya liken AE tenn?
Old May 22, 2007 | 10:43 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
John your title is missing to s's, or either your myspace name has two extra
Old May 22, 2007 | 10:51 PM
John311t's Avatar
John311t
I dont think they they will let me post that. They mite ban me.
Old May 22, 2007 | 10:58 PM
Tenn01PSD350
I hate it. I haven't even scratched the surface yet. Stupid POS. I have resigned myself to realizing that I need to gather a bunch of info from the shop manual so that the values I see while datalogging actually mean something.
Seriously, there's way more there than I had time to play with last weekend and the wife had other ideas about what was going to happen. Because the thing is so cool I am going to try to assemble some how to tests complete with expected values etc. Sorta what Alan has begun on 7point3. And don't think I won't use what's there.
So I love to hate it. As with all the other irons I have in the fire, this one will proceed in a glacial manner as well. I can't wait until I retire again so I can fart around and not have to work.
Old May 23, 2007 | 06:47 AM
Uzumati's Avatar
Uzumati
No need to uninstall 5.0 to do the update just run it and it will overright the 5.0 and it will keep your activations.
fordpride
15
May 23, 2016 01:00 PM
fordpride
Jun 26, 2012 10:49 PM
FTE Ken
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Dec 10, 2008 07:46 AM
ron's power stroke
20
Jul 9, 2008 05:17 PM
cef2lion
Jul 9, 2007 04:37 PM
