Oil Undercoating
Old Dec 31, 2010 | 02:30 PM
cpettymore7777's Avatar
cpettymore7777
Oil Undercoating
i hear some people in the northeast spraying motor oil on the undercarriage of their trucks in the fall and it suppose to prevent rust. is this true? do they just spray the frame or body and everything?
Old Dec 31, 2010 | 05:22 PM
2005f-150's Avatar
2005f-150
i live in the rust belt and have alwayse sprayed used motor oil under my truck after every other oil change and my dads 1989 f-250 looks better underneath than from the top. i spray everything even the exahust.yeah it smokes for a while but never replaced the exahust on it either. from my experiance this is a far better rust proofer than undercoating, because after a couple yeaars it starts to peal off leaving places for salt and water to lay.best of all used motor oil is free..
Old Dec 31, 2010 | 06:58 PM
Volvo92906's Avatar
Volvo92906
I use used diesel oil from the trucks where I work. It makes a helluva mess but it protects the frame and as 2005f-150 said, its cheap.
Old Dec 31, 2010 | 07:29 PM
CJM8515's Avatar
CJM8515
best stuff I ever used is called fluid film, it goes on thick and doesnt come off
Old Dec 31, 2010 | 07:39 PM
g_k50's Avatar
g_k50
Wash undercarriage in mid season.
Old Dec 31, 2010 | 08:15 PM
kevin206's Avatar
kevin206
I've heard of the same trick used in Mexico, but they brush on the used oil.
How would you get the oil to "spray"? What could you use for the applicator?
Old Dec 31, 2010 | 08:24 PM
g_k50's Avatar
g_k50
construction workers use a oil applicator can that is pressurized to spray form oil on their forms so that it releases from the concrete.
Pressurized sprayer should find you one on google.
Old Dec 31, 2010 | 08:47 PM
cadillacmob's Avatar
cadillacmob
i use a paint sprayer i got at harbor frieght, was around 20 bucks or so. Air powerd
Old Dec 31, 2010 | 08:55 PM
Jigger2020's Avatar
Jigger2020
dont forget to spay inside the doors & under inside the hood
Big-Red-Lariat
2015 - 2020 F150
27
Oct 10, 2018 09:33 AM
unibody62
Garage & Workshop
Nov 2, 2016 10:35 AM
Big-Red-Lariat
2015 - 2020 F150
Mar 21, 2016 03:29 PM
texastech_diesel
Mar 7, 2016 09:54 PM
jbrianas
Jan 1, 2013 07:37 PM
