1975 crewcab locally, decoding the VIN?
Old 12-31-2010, 01:36 PM
78bigunns's Avatar
78bigunns
78bigunns is offline
Found it on CL. Thinking about picking it up.
I wanted to verify it came as a dually, what rear it may have, what ratio if possible.
Current drive line is a 460/c6.
From the door plate:
F35MCX20389
167 MF F351 33D GD6J
08000 1975 89
The axle did not have a tag, but this number was stamped in the housing:
034835 Maybe a Dana 70?
Tried searching for Vin decoder, decoder, but I'm getting some random threads.
Pics:
Old 12-31-2010, 01:46 PM
78bigunns's Avatar
78bigunns
Got it. Looks like it had a 390 original, then swapped to a 460. Can anyone confirm?
Everything else looks good. Just had to dig little deeper than I did on the 1st couple searches then hit the FAQ.
Old 12-31-2010, 02:06 PM
impalaslayer's Avatar
impalaslayer
impalaslayer is offline
jealous..........
Old 12-31-2010, 02:09 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Ziegelsteinfaust is offline
Wow I wish I saw one of those.
Old 12-31-2010, 02:25 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
F35=F350 Pickup
M=390 cu in 4bbl V8
C=Ontario truck plant
X20389='75 model year serial number
WB 167= 167" wheelbase
Color MF= (M) white (F) dark ginger metallic
Model F351= F350 pickup 8000 GVW
Body 33D= (33) Light and medium ginger vinyl (D) Ranger cab w/ styleside box, crew cab
Trans G= Automatic transmission
Axle D6J= (D6)= Dana 70 limited slip 3.73 ratio (J) power steering
GVW 08000= 8000lb gross vehicle weight
1975= 1975 model year
DSO 89= Transportation Service
Old 02-19-2011, 10:13 AM
78bigunns's Avatar
78bigunns
Wanted to come back to this, just as a update. It showed up on a trailer today. After much wheeling and dealing, for $750.
Can't beat that.
Thanks for the rundown Mike!
Old 02-19-2011, 10:35 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
Now that ya got it home tell us more. Rust issues? Mechanical issues? And lots more pic's. What's your plans with it?
Inquiring minds need to know.
Old 02-19-2011, 04:02 PM
78bigunns's Avatar
78bigunns
No rust issues, except heavy surface stuff on frame as expected. No rot anywhere I can find. Still has paint in the bed.
The 460/C6 was in a mild flood. Water got as deep as the floor boards. The engine is semi seized.
The PO has dumped diesel in both, but regardless, he wants them to go through and after rebuild install in a Lincoln project.
I picked up a 81 460/C6 out of a motor-home. Went and gave it a run, purred like a kitten, ran real good, that cost me $600.
The engine seller owns a shop next town over, and is pulling the 81' 460/c6 soup to nuts as part of the deal. Some new valve cover gaskets, removal of smog stuff, a good intake and headers, it will get dropped in the 75' crew.
After that, I'm going to reline the tanks if needed, although they look really good, do some overall service, go through the brakes, do a good interior cleanup, give it the best quickie paint job I can, put on some tires (shame cause, the tires on it are new but dry rotted), then drive the **** out of it.
Has a nice dual exhaust setup on it now, that will stay.
It will be my dump runner, Lowe's bish, pull my Jeep on the flatdeck. Pending how well the paint does, it might get driven to the local cruise in's.
Old motor will be out by tomorrow.
Old 02-19-2011, 06:01 PM
arctic y block
Keep us posted and more pic's
Old 02-19-2011, 07:58 PM
78bigunns's Avatar
78bigunns
No problem, glad to share. Will get some more pics tomorrow as we pull the engine, and clean up the inside.
JacoFordCummins
Engine Swaps
45
11-04-2020 09:09 AM
78bigunns
11-28-2014 10:19 PM
78bigunns
18
11-27-2013 07:16 AM
78bigunns
Electrical Systems/Wiring
03-03-2013 11:06 AM
78bigunns
Appearance & Dress-Up
10-10-2012 05:26 PM
Quick Reply: 1975 crewcab locally, decoding the VIN?
