Will die when Idel drops too fast
Old Dec 31, 2010 | 06:40 AM
jrodtaclet's Avatar
jrodtaclet
Hello, and thank you. Here is the problem I have on my 90 f150 4.9. 5 speed with 100k miles. The truck runs nice and smooth however when the RPMs drop too fast it will die. Example: I'm driving 55mph at 2000 rpm and put it in neutral approaching a red light, the truck will die as the rpms drop too fast. However if im driving and slow down to less than 1000Rmps. I have no issues. So when Im driving and I'm approaching a stop light, I just brake until my rpms are below 1000 an put it in neutral so my truck will not die, is not a major issue but im sure there is a fix for it. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Thanks<o></o>
<o></o>
Old Dec 31, 2010 | 07:19 AM
rla2005's Avatar
rla2005
The most common cause of your issue is a dirty/faulty Idle Air Control (IAC) solenoid. It is attached to the side of the throttle body. Do a search on IAC, this subject is brought up every single day on this forum. Long story short it can be cleaned, but many times it is a short term fix. A replacement may be in your future.
Look here for reference: Ford Fuel Injection » Idle Air Bypass (IAB)
Old Jan 10, 2011 | 01:32 PM
jrodtaclet's Avatar
jrodtaclet
I have replaced the IAC and is still doing the same thing.
Old Jan 10, 2011 | 04:09 PM
jv2290's Avatar
jv2290
Could be a stuck EGR valve or a fault in the EGR system. If it's stuck or not closing all the way it's like a vacuum leak. I've had 2 trucks that have done that. You can try pulling the vacuum line from the EGR and plugging it to see how it works. Your check engine light will be on but it won't hurt anything.
Old Jan 10, 2011 | 04:42 PM
jrodtaclet's Avatar
jrodtaclet
Thank you, my EGR vaccum hose is disconected, this is the only way my turck runs great. I notice that my truck only has an issue once it warms up. Is not a big issue as I've learn to slow down before I put it in neutral. Thaks
Old Jan 10, 2011 | 05:21 PM
jv2290's Avatar
jv2290
If it's only when it heats up it could be the ECT (Engine Coolant Temperature Sensor) located on the water outlet.
Heres a link with info on that. Ford Fuel Injection » Engine Coolant Temperature Sensor (ECT)
Old Jan 10, 2011 | 06:53 PM
rla2005's Avatar
rla2005
So now we have a little bit more to the story. If you had added that tidbit of info initially it could have saved you some $$$ and time. Until you resolve your EGR system issue, you will have the side effect you started this thread with.
Old Jan 10, 2011 | 06:57 PM
oldfordisbetter's Avatar
oldfordisbetter
my truck does same thing. has high idle but also rpm will drop and sometimes stall or almost stall... 92 5.8 5spd 4wd.
Old Jan 11, 2011 | 09:06 AM
jrodtaclet's Avatar
jrodtaclet
I see, i guess i can live with it. No big deal. Thank you all.
TexasEX2K
Jul 5, 2012 10:46 PM
Mochosla
Jul 23, 2011 11:14 AM
Mike821
Feb 16, 2011 10:20 AM
K8's Ford
13
Oct 19, 2010 05:39 PM
KCGman
Jan 22, 2010 07:16 PM
