Sponsored by: Real Truck
autohub problems
Old Dec 31, 2010 | 06:03 AM
maxuk's Avatar
maxuk
autohub problems
Hi guys,
I have a vacum problem with the pulde solenoid if I blank the vac pipe comin into it it builds vac no probs. if I blank the vac pipe goin to the hubs it won't. I have taken it of the firewall and you can feel the soleniod movin. However it seems to be leaking thro the 2 ports in the top.
Should it have some sort of bowl on the bottom? maybe its got knocked of when the batteries where changed?
I am guessing this solenoid sends a pulse of vacum to the hubs one to pull they into drive and then release the vac as the hubs catch within them selses and then another to release them?
I think the pulse solenoid may be knackered anybody know the best place I can order of the internet as I am over in the UK!
Thanks guys,
Max
Old Dec 31, 2010 | 09:26 AM
dchamberlain's Avatar
dchamberlain
I've seen cases here before of vacuum solenoids failing and starting to leak. So it's certainly possible. If the vacuum pump builds a vacuum and shuts off with the line going to the solenoid plugged, but does not do so if the switched port of the solenoid is plugged the it seems like you've identified the problem.
There is a member here who does online sales of Ford parts. His prices are very reasonable and he is very helpful. I don't know much about shipping to the UK though.
Go to www.partsguyed.com. Create an account there and send him a message describing what you need. He'll get back to you with information.
Old Dec 31, 2010 | 09:41 AM
maxuk's Avatar
maxuk
Hi
Many thanks I'll have to contact him as I don't have a clue what a fein number is!
Thanks
Max
Old Dec 31, 2010 | 09:47 AM
dchamberlain
If you describe the part to Ed and give him your VIN number he will give you the right part number and part.
The proper name for the solenoid is the PVH Solenoid. PVH means Pulse Vacuum Hublock.
Old Dec 31, 2010 | 04:11 PM
maxuk's Avatar
maxuk
Cheers happy new year from the uk!
Old Jan 3, 2011 | 04:24 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
7C3Z9H465A
ORDER AWAY!
midgainc
37
Aug 7, 2014 08:37 PM
jeem
Sep 16, 2013 09:05 PM
dcara
Aug 20, 2012 12:51 PM
psvienneau
Nov 27, 2011 03:06 PM
ralph54
25
Oct 21, 2010 11:56 AM
