Wheel not centered in opening
Old Nov 24, 2014 | 11:18 PM
  #31
54-F100's Avatar
54-F100
Newbie opening up old threads...Are your wheels centered?
Just checking in to see what the thoughts are on the front axel/wheel center location...
Is it move it forward 1" and center on fender?
Is it move the axle 4" or 5" forward and then reshape the fender sheet metal?
It would seem to me that a longer wheel base would possibly improve the ride and overall handling. Would like to get your thoughts.
Also, thanks for posting the link to "slicing & dicing your wheel wells" as it cleared up some questions I had.
So, if you were starting a new build, then where would your perfect placement be for a new IFS?
Old Nov 25, 2014 | 07:42 PM
  #32
Dale Fairfax's Avatar
Dale Fairfax
Was wondering what your opinion is. Do you think it's off center enough to doctor the opening or should I just live with it. My calulations figure the wheel is between 1 to 1 1/2" forward of center. If I do decide to cut up the fenders I figure I'll cut up the F600 fenders I have and save these for my pickup.
Several months ago, Denver Slim posted pictures of my '53 F-100 (the one with the 337"Flathead engine). Careful measurement determined that the front axle centerline was 1 1/4"too far to the rear-relative to the wheel arch in the fender. My arbitrary assessment of the looks of the truck (and ALL F-100s) was that the wheel arch was 3" too far rearward. A fairly simple bit of slicing and dicing of the fenders moved the arch forward 3". I then moved the axle & springs ahead 4 1/4". In my opinion , the appearance was improved significantly. However, there is a caveat: Moving the axle assembly forward also moves it downhill on the frame thus raising the front of the truck. Some compensation is necessary-like a "c "notch at the front spring hanger. I fixed it by diddling with the springs. (the hard way).
Old Nov 25, 2014 | 08:11 PM
  #33
wallys 54's Avatar
wallys 54
54 F100, I just test fit a Mustang II IFS kit at the factory recommended placement. They suggested 19 3/4" from the center of the front shackle mount and after fitting it up and placing the fender, it ended up being within a 1/4" of the center of the fender. I personally like the way it looks centered but to each his own!
Old Nov 25, 2014 | 08:34 PM
  #34
54-F100's Avatar
54-F100
Thumbs up 53-56 F100 Front Fender Modification
Thanks Dale...that's good info.
I did find a couple of builds that showed how they did the fender modification:
1) Roadster Shop did this one 1953 Ford F-100 - Classic Trucks Magazine
2) "Snakebit" the Shelby inspired truck https://www.flickr.com/photos/905664...7632629869486/
Maybe this will help someone complete the fender modificaitons
Mattyhawk
Aug 5, 2018 10:47 AM
Thisguy65
May 29, 2017 11:50 PM
53fordman1
Feb 11, 2016 11:27 AM
jg96powerstroker
Feb 3, 2016 07:30 AM
DoctorB
41
Dec 16, 2015 09:38 AM
