ScanGauge FWT - ECT
Old Dec 31, 2010 | 09:04 AM
Misky6.0's Avatar
Misky6.0
Originally Posted by npccpartsman
I had to set mine to CANSF for it to connect to my PCM and tried "All" and "Supported" PID's to keep it from going to sleep even with the key on. Still goes to sleep after I shut the engine off even with the key "on".
There are a couple of different trans temp commands to try. Did you find them both? This is the one that works on my 04:
TFT 07E1221674 046205160674 3010 000100080000 TFT Degrees F
I just got my SG on Monday so it's got all the latest updates. You might want to check the firmware version and send it for the updates, which I "think" are free. Their website has the info. I'd go out and check mine but the weather is just plain NASTY right now so I'll get it and check back.
Unless the engine is running the scangauge2 goes to sleep,
even with the key on. I think it even went to sleep while
programming the PIDs, if I stopped to lookup the next data value to enter.
I've also observed during the long glow plug warm up cycle on cold days,
it doesn't come ON until the engine starts too.
You can press the bottom right button to manually turn it "on" or "off"
with the key in any position.
Hope this helps.
Old Dec 31, 2010 | 09:41 AM
npccpartsman's Avatar
npccpartsman
Hope this helps.
My experiences exactly. I guess they had to have someway to make it sleep but I don't understand it sleeping with the key on.
Old Dec 31, 2010 | 10:18 AM
frenchy750's Avatar
frenchy750
FWIW, I have Scangauge firmware version 3.17mb. I found that I can't display the same parameter twice, so for example, if I load ECT in two positions, only one ECT will give a reading.
I was able to load both the newly defined ECT and the original fWT, and both parameters gave me identical, or at least nearly identical readouts.
According to their website, Scangauge does offer an upgrade to the current firmware for units purchased after July 20, 2007. I assume this update would add the Xgauge features to a non-Xgauge device. That info can be found here: ScangaugeII Upgrade
Old Dec 31, 2010 | 11:09 AM
High Binder's Avatar
High Binder
ScangaugeII Upgrade
Cool, thanks for the info that's just how mine is so you and I must have the same firmware version.
TacoSplitter
Sep 20, 2016 08:37 PM
smlford
Mar 24, 2015 07:21 PM
Bruin008
Dec 26, 2012 09:04 AM
cay5628
May 14, 2012 06:41 AM
SHAWN056.0
Jul 7, 2010 05:09 PM
