fuel Injector help!!!
Old Dec 27, 2010 | 08:13 PM
bigdog13's Avatar
bigdog13
I have A couple Questions on my fuel Injectors...
I have 2004 F250 6.0l
the truck truck run really bad when cold say below 40degs I checked the FICM and it gets about 48volts
1. when "buzzing" the Injector should they buzz or do they just "click" mine just click
2. all the Injector click but two... 6 and 7
3.when the truck is warmed up they all "click" and runs good
4. the only codes are stored code P0281,P0603,P0671
thanks for any help....
Old Dec 27, 2010 | 09:03 PM
cheezit's Avatar
cheezit
they should just click
sont worry about dtc p0603. that a pcm reset code. Check your batteries though.
when you say about 48v... whats about mean?
p0281 cyclinder 7 balance code. this could be an injector issue.
p0671 glowplug #1 issue.
Old Dec 27, 2010 | 09:18 PM
bigdog13's Avatar
bigdog13
i am getting about 48volts on the FICM...
I just had the batterys unhooked when I did away with the EGR cooler...would that be the P0603
cheezit's Avatar
cheezit
yup that would be the p0603
Old Dec 27, 2010 | 09:30 PM
bigdog13's Avatar
bigdog13
Why when the truck is cold Injectors 6/7 will not "buzz" but when the engine warms up all the Injector "buzz" I am just tring to under stand..
I think I am going to "rebuzz" the injectors in the morning to double check the test...
thanks for your help
Old Dec 27, 2010 | 09:31 PM
cheezit's Avatar
cheezit
the click you are hearing is the spool valve. if its stuck do to "latching" it wont click.
Old Dec 27, 2010 | 09:43 PM
bigdog13's Avatar
bigdog13
I take the only thing to do is to replace them? and how can I help the rest of the Injectors from going bad? what do you mean by "latching"
I change my oil about every 3500 mile and use OEM filters...
Old Dec 27, 2010 | 09:47 PM
3000 FPS's Avatar
3000 FPS
Are you referring to the stiction that occurs when the valve will not always open and close.
Old Dec 27, 2010 | 09:49 PM
cheezit's Avatar
cheezit
yup thats were this is going.
most commonly caused by lack of correct maintace.
Old Dec 27, 2010 | 09:57 PM
bigdog13's Avatar
bigdog13
Like I sed I change my oil about 3500 give or take 200 miles change fuel filters every other oil change. fuel filter alway look pretty good never real dirty...never get much water out of the plug maybe a half of a teaspoon when I change my oil I use the motercraft fuel add when I fuel up...
Old Dec 28, 2010 | 11:44 AM
3000 FPS's Avatar
3000 FPS
Hey Bigdog try a search in the 6.0L forum on stiction and you should find some answers there. This is a problem that affects alot of these trucks.
Old Dec 31, 2010 | 12:09 PM
bigdog13's Avatar
bigdog13
I "buzzed" the injectors couple of mornings... first time I buzzed them 6/7 injectors didn`t buzz.... next morning 3/4/6/7 didn`t buzz... next morning it was was just injector 7... not sure what to do with it... The mornings I buzzed them I buzzed them a couple time each morning... don`t want to replace more then what I have to...at $200 each... thanks for the help...
Old Dec 31, 2010 | 12:22 PM
mixerdrvr's Avatar
mixerdrvr
As posted before, search for stiction. Some things reported to help is changing to synthetic oil, rev x or hss.
Hope this helps
