Bronco II Ford Bronco II
89 BII center console
Old Dec 29, 2010 | 08:57 AM
tommyleea's Avatar
tommyleea
I have the center console with the armrest that swings up. Plastic part of the hinge broke. I bought a new hinge, but I am at a loss as to how to remove the old hinge from the armrest itself. Has anyone replaced one of these hinges before? Thanks.
TommyJ
Old Dec 29, 2010 | 05:10 PM
Eddiec1564's Avatar
Eddiec1564
Its been awhile since I took my ole busted hinge off. There are 6 or so screws that hold the outer shell to the inner base. Some are in the box and change holder area. That should lift up and you'll see 4 screws or bolts that hold the hinge in place.
So the hinges are still avliable!! Whats the part# and were you found them.
Old Dec 29, 2010 | 07:37 PM
tommyleea's Avatar
tommyleea
I bought it at LMC. Don't have the part number handy. I see how the hinge bolts to the console, but can't figure out how it attaches to the armrest itself. I don't want to destroy the armrest part. Thanks
TommyJ
Old Jan 2, 2011 | 06:03 AM
ncranchero's Avatar
ncranchero
I think Eddie is speaking of the console lid hinge.
THIS AND THIS is the hinge replacement, used to could find them anywhere, more rare now. I have had quite a few B II's and replaced one back years ago. You have to cut the pin from the old one. I used a cut-off wheel on a die grinder. The new one will pop back into place when pressed hard enough. I don't find the instructions online anywhere to do this though. Did the new one you purchased not come with any instructions? I know it said to use a hammer and piece of wood to re-seat the new pin. That replacement part fits all Bronco II and Gen 1 Explorer arm rests. The photo is actually from my broken rest from my 2002 Sport trac. All of these rests attach to the console mounting bracket the same....exactly.
Search for these OEM #'s F37Z10047A20F (tan/mocha) - F37Z10047A20D (gray/smoke) · F37Z10047A20G · F37Z10047A20H
LMC # is 50-8800.
Old Jan 2, 2011 | 07:23 AM
tommyleea's Avatar
tommyleea
Thanks, that will be todays project.
Old Jan 3, 2011 | 07:58 AM
tommyleea's Avatar
tommyleea
Thanks for the info, that procedure worked like a charm. A little scary installing the new one, but it went in. Nice to have an armrest again.
TommyJ
Old Jan 3, 2011 | 08:47 AM
ncranchero's Avatar
ncranchero
Glad it went well and if you need anything like that pin-out again just PM or email me.
Old Jan 3, 2011 | 09:42 AM
tommyleea's Avatar
tommyleea
Copy, Thanks, Will do
mattri
Sep 8, 2016 01:06 PM
15expedition
Aug 3, 2016 07:17 PM
mrcman58
WTB - Parts & other
Mar 24, 2016 06:04 AM
mikereidjr
Aug 19, 2015 07:54 PM
cbnewman
Jun 24, 2002 11:15 PM
