205 transfer case
Old Dec 28, 2010 | 05:34 PM
bigdaddys76's Avatar
bigdaddys76
205 transfer case
The answer may be as simple as "its a full-time trans case" but here goes,
when I shift trans case into ANY gear and then put transmission into gear my front drive shaft turns as well as the rear wether it be forward or reverse.
Is this normal for the 205 and o.k. as long as my front hubs are not locked in?
Model 205 Ratio 196
Serial 9 9 76
Assembly # D7TA7A195CA
Old Dec 28, 2010 | 05:54 PM
bigdaddys76
Just Googled a 205 and they are part time, so what gives?
Is it simply cause I dont have the front drive shaft in and it would not turn then?
Old Dec 28, 2010 | 05:56 PM
jnkyrd1's Avatar
jnkyrd1
Fluid drag on the gears. If you watch some going down the road you will see it just about all the time. By the way hope you had a good Christmas.
Old Dec 28, 2010 | 05:58 PM
jnkyrd1's Avatar
jnkyrd1
Wait! Is it being powered or can you stop it? Call me when you get a chance it will be easier that way. Jeremy
Old Dec 28, 2010 | 06:09 PM
LongTravelHighboy's Avatar
LongTravelHighboy
I thought thats what was supposed to happen...is it not supposed to rotate?
Old Dec 28, 2010 | 08:00 PM
mark a.'s Avatar
mark a.
No it isn't supposed to turn. As stated it can turn some by just the oil in it. Reach under there and see if it is free when the transfer case is in 2 high.
Old Dec 28, 2010 | 08:40 PM
LongTravelHighboy
It was not free so i bumped the shifter/selector forward some and it free'd up. I wonder how long its been like that as i ***(outta)u(&)MEd that was just the 70s technology. These trucks must have been built for people like me, they are so tough you cant break them with even an enormous amount of ignorance!
Thank you
Thunderhorn
1978 - 1996 Big Bronco
Dec 5, 2015 11:06 PM
hickory1991
Jan 8, 2015 07:49 PM
dig'umz
Feb 18, 2013 10:50 PM
74ford4x4
20
Jan 16, 2011 11:25 PM
