Well last night the temp dropped below -18f and this morning the oil temp and coolant temp after about 2 minutes of running was 2f.... Truck started but this time it didn't crank with much vigor....and considering I'm in the middle of nowhere I don't want to push fate.... I installed the heater plug recently but never used it... This will be my first time so have question... Can I leave the truck plugged in all night? Will I awaken to a charred mess?... Using a new 12gauge extension will this be enough.... Temps were now is 6f and expected to drop well below zero again tonight..... Thoughts and opinions
Yes you can leave it plugged in all night but you wouldn't kill your power bill as bad and you would have virtually the same effect if you just plugged it in 3 hours before you started her up.
The heater may be plugged in all night. I have done this several times, but in reality 3-4hrs is all that is needed. Remember the block heater is like having a coffee maker on all night (1150 watts I believe) so your meter will be spinning a little faster. Mine at 10* for 4hrs shows a water temp of 80-100*f and oil temps just a little lower. Keep in mind you are only warming a fraction of oil and coolant. As far as cord I bought a thick one lol Dont remember size or amp rating. O block heater draws about 10amps IIRC.
Was at home depot today and no heavy duty timer..... Will try loews next.. As for the battery tender I keep one in the truck all the time...and plug it in at least once a week overnight....
I honestly would not use a timer given the amount of heating you need to do, I would just leave it plugged in all nite.
I'm running motor craft 15w40....started right up... But didn't turn over real quick... When It fired up it went into a nice smooth idle... But when I got back in the truck from cleaning off the ice I noticed that the oil temp/coolant temp
Was 2f .... But I have to say not sure if it's the new flash the truck went right into a smooth idle.... No knocking...
