Sponsored by: Auxito
Stock FX4 wheel question
Old Dec 28, 2010 | 01:09 PM
DanielB's Avatar
DanielB
Finally found the factory rims for my truck. Just took 3 months. I have a question. Did the factory setup have lug nut covers or anything specific other than the bare lug nuts. Flat style of course.
I'm trying to hunt down some factory lug nuts. But don't want to just grab the first ones I can if I need something specific.
Old Dec 28, 2010 | 03:37 PM
phil6608's Avatar
phil6608
I think we would need the year and size? Maybe a pic if ya have one.
Old Dec 28, 2010 | 03:45 PM
DanielB's Avatar
DanielB
I guess I failed to put my signature together back in September.
2002 F150 Screw FX4.
Picture pulled from the internet.
Old Dec 28, 2010 | 03:58 PM
phil6608's Avatar
phil6608
I think ya need over 25 post to make your sig.
They look like the lugs will show so get something that looks good.
Old Dec 28, 2010 | 05:25 PM
steve(ill)'s Avatar
steve(ill)
should be bignuts with flat washer built into the backside... they will show, so probalby had chrome castle caps on each nut.
Old Jan 7, 2011 | 04:37 PM
DanielB's Avatar
DanielB
Finally found lug nuts for the truck. Ford specs a Stainless Steel lug nut for the Fx4 package. However at around $10 per lug nut for these I said screw it.
Dorman 611-230 is the product number. They are a chrome finished lug nuts with the attached flat washer. They look similar to the acorn nuts common on aftermarket rims. Similar domed top. Dorman lists a chrome capped lug nut on their site. I did not find the price on them. The nuts I picked up were $.99 each. Not bad considering the factory alternative would cost $200.
I bought these through O'Reilly Automotive.
Figured I'd post this for those that my be searching in the future. Now I just have to decide if I'm going to buy new tires now and sell my old rims and tires together or just swap tires.
Old Jan 8, 2011 | 09:08 AM
fordf150farmer's Avatar
fordf150farmer
If you havent already run into a problem, becarefull. i did this same swap to my truck and couldn't use the lugs that came with my wheels because my 97 has 12mm studs and the 02+ have 14mm. just thought i would throw this out there as im not sure what year they changed stud size.
Old Jan 8, 2011 | 09:58 AM
DanielB's Avatar
DanielB
02 truck have the 14mm studs that is correct. These lugs are for the 14mm studs.
Old Jan 8, 2011 | 10:33 AM
phil6608's Avatar
phil6608
Not sure when they switched ether. I know 99 still had 12mm. I think they changed in 2000 to 14mm
Old Jan 8, 2011 | 03:25 PM
fordf150farmer
on a side note, i would love to find some nice lugs that look like they match what should be with the FX4 wheels, but i need for 12 mm studs, Any ideas? is there another ford vehicle that would have the lugs i need?
Old Jan 8, 2011 | 05:01 PM
galaxie641's Avatar
galaxie641
Ford had them a few years ago but it was at a ridiculous price when you figure 20 of them
are needed. I think I found them in their Ford Racing catalog back then. Needless to say
my original 12mm's work just fine, you'd have to be on your stomach to see them down
in there.
Old Jan 8, 2011 | 07:52 PM
DanielB's Avatar
DanielB
Dorman Products - Application Guide Results
ask and you shall receive. 12mm lug nuts. chrome finished. Not capped. I didn't make it to the tire shop today to get my wheels switched out. However I did drop the lug nuts into the holes and took a look. Perfect depth in the hold and they look good. And for $180 less than what Ford was charging.
Deuce3301
Mar 6, 2017 02:39 PM
73strokin
31
Nov 20, 2013 06:37 PM
80s Trucker
Jul 17, 2009 07:59 PM
jlalanas
May 13, 2009 06:20 PM
DS02F250
Dec 18, 2004 06:29 PM
