6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 REgen
Old Dec 28, 2010 | 09:45 AM
n2kars's Avatar
n2kars
6.4 REgen
I have a 08,F-250 with a 6.4 with 52K, Question, Its been nearly 2000 miles since a regen. No engine ligh problem everything works, runs perfectly. Anyone experienced this before?
Old Dec 28, 2010 | 09:52 AM
senix's Avatar
senix
I am sure it is regening...PCM commands it around 600-650 no matter what.
I think the issue is you had your PCM undated to the latest flash which removed the continious message of "cleaning exhaust filter".
Good news is that the truck is running as designed. A properly running system should perform behind the scenes with no drivablity concerns.
So is that what took place? a recent flash in the last few months?
Old Dec 28, 2010 | 10:12 AM
n2kars's Avatar
n2kars
Ihave not had the truck into the ford lately. I pull a fifth wh camper, went ot tenn this summer, it went into regen several times in the mountain driving. As I returned back home it momantarly flashed once, but has not gone into rergen in over 2000 miles. I get good milage no smoke, clean tail pipe. When I run the data scan all shows good.??????
Old Dec 28, 2010 | 10:19 AM
senix's Avatar
senix
so it used to show the message till it was finished and now it does not?
Old Dec 28, 2010 | 10:22 AM
n2kars's Avatar
n2kars
correct. It would go into regen about every other tank of fuel.
Old Dec 28, 2010 | 10:28 AM
senix's Avatar
senix
interesting...No programmer either?
Old Dec 28, 2010 | 10:31 AM
n2kars's Avatar
n2kars
No, pure stock
Old Dec 28, 2010 | 10:34 AM
senix's Avatar
senix
I'd say leave it alone. As long as there are no concerns, pipes are clean, not making oil or losing coolant.
Old Dec 28, 2010 | 10:38 AM
n2kars's Avatar
n2kars
My little ford tech man at the local dealership,says if the check engine lite is not comming on it probably O.K.
Old Dec 28, 2010 | 10:44 AM
senix's Avatar
senix
exactly, i probably has passively regened on you.
Old Dec 28, 2010 | 04:22 PM
powerstroke72's Avatar
powerstroke72
Moved to 6.4L Power Stroke Diesel forum.
Old Jan 10, 2011 | 12:14 AM
soling2003's Avatar
soling2003
MIne has pretty much done the same thing on my 2010 F250. Everyonce in a while I get a puff of white smoke out the exhaust for a minute or so. But I do think my MPG's have gone down just a bit. It used to get 15-16 ave. when new, now down to more like 13-14 with all around driving.
Oil was changed at 4800 mi. by dealer. New windshield wiper motor at that time too.
Everything else seems to be fine. Plenty of power. haven't towed the 5th though for a few months.
Old Jan 13, 2011 | 08:37 PM
Papi4baby's Avatar
Papi4baby
Listen for a change on the engine sound. It will sound more like an old diesel engine, when it does this, flick the odometer settings until you reach hold to test(or system check).
Do that, if is doing regen, after all the checks it will display the cleaning exhaust filter.
bobbyg
6.7L Power Stroke Diesel
25
Nov 13, 2014 05:23 PM
F250GH
20
Jul 9, 2013 10:51 PM
jmacr12
Jun 16, 2011 03:24 PM
Champ198
27
Aug 22, 2010 10:18 PM
Rafiki2cu
30
Jun 28, 2010 08:41 PM
