injectors?
Old Jul 30, 2003 | 08:16 PM
gotgrouper?'s Avatar
gotgrouper?
injectors?
can i put 24# injectors on a '79 302 w/ no other mods? would it help?
thanx, mitch
Old Jul 30, 2003 | 09:26 PM
fordeverpower's Avatar
fordeverpower
injectors?
what kind of setup are you running on a 79 302?
Old Jul 30, 2003 | 09:37 PM
mikeindmills's Avatar
mikeindmills
injectors?
i would assume that you're running a fuel injection setup. and a stock 302 would not need 24 injectors. all that would do would be to add too much fuel to the mixture. a lot of the time, it will get into the oil and thin it out, causing serious motor problems. stick with the 19s, there's a lot of ther cheap ways to get power.
Old Jul 30, 2003 | 09:54 PM
fordeverpower
injectors?
I was wondering why there is injectors on a 1979 motor. I thought fuel injection strated in 1986 for trucks. But if it is fi the 19lb injectors would supply plenty of gas to a stock 302. I do believe the 19lb injectors are rated up to 300 hp before bigger ones are needed.
tpc3
Dec 13, 2013 08:36 PM
danielwd
1983 - 2012 Ranger & B-Series
Jan 2, 2011 10:18 PM
turbill
Dec 22, 2010 06:59 PM
SAltonS
Dec 18, 2009 08:36 PM
Nathan
Aug 5, 2001 08:58 PM
